1 - 2 of 2 Posts
· Registered
Hi,
I am looking to a purchase a Samsung 2019 "The Frame" TV. the house is currently under construction so I have chance to get a conduit placed into the wall to run the one connect cable to the TV mounted on the wall. What is the minimum size conduit required to fit the connectors through?
I found this documentation that shows the plug sizes:
MOLDING PLUG SIZE (W x H x D): [TV] 1.89 x 3.34 x 0.44 ; [OC] 1.15 x 2.84 x 0.54:
https://image-us.samsung.com/Samsun...Invisible_Connection_Spec_Sheet_R2_051719.pdf
MOLDING PLUG SIZE (W x H x D): [TV] 1.77 x 3.34 x 0.38 ; [OC] 0.99 x 2.76 x 0.54
Can anyone with installation experience recommend a wall conduit diameter that will work easily?
Also, at the bottom of each document it states for the 15m cable: "*This optional longer length cable is not designed to meet in-wall installation codes"
Does in-wall mean the same as "in conduit"?
· Registered
No experience in building codes/installation, but I'd go 2 inch diameter minimum to be safe(be sure your plug ends fit through). As for the conduit, plastic if code allows. Bare in mind it's never a good idea to run power/video lines next to audio lines(arc).
Best
1 - 2 of 2 Posts
