1 - 4 of 4 Posts
Well I thought this would be a simple thing to do but for whatever reason it doesn't work.
Since my HTPC can't output proper audio through HDMI I'm forced to go with optical.
HDMI input -> DVD/BD -> HDMI1
Digital input -> DVD/BD -> Optical 1
This should say get your video from HDMI1 and your audio from Optical1, right?
However, when I select DVD/BD I get video but no audio.
What am I missing?
The Village Idiot
The 507 is capable of using HDMI audio signals. Unless your video card explicitly states it passes audio over HDMI you'll need the optical or coax for sound.
I think the 507 has assignable inputs. Unless you've assigned audio input for the video channel you'll get no audio.
See page 11 in your manual.
Discussion Starter · #3 ·
As far as I can tell I have hooked everything up correctly, it seems that the 507 may be unable to receive audio from a different source when HDMI is set as the input.
Can anyone verify this?
As a test I hooked it up as stated below and it worked, when I selected CD, but if I reset it as I had before, I only get video.
Digital input -> CD -> Optical 1
The Village Idiot
See page 43 of your manual - audio inputs are assignable - even for HDMI.
1 - 4 of 4 Posts
