Here are the details : http://dtsx.onkyousa.com/
From the specs I'm reading three ports compatible with HDCP2.2.8 HDMI 2.0a/HDCP 2.2 ports.![]()
On Facebook they said they don't have any info yet.Missing from the List
TX-NR848
TX-NR1040
TX-NR3040
When will these get release?
"Joining next-generation audio decoding are eight 4K/60 Hz-ready HDMI® 2.0a inputs and two outputs, including dedicated HDCP 2.2-compliant terminals for 4K streaming and UltraHD Blu-ray with Dolby Atmos or DTS:X audio (due later this year). High Dynamic Range (HDR) color and 21:9 cinema-aspect are also supported."From the specs I'm reading three ports compatible with HDCP2.2.
Affordable and pre-outs seems to be a dying breed. You have to step up into the upper-mid range to get pre-outs nowNeed an affordable one with pre-outs, otherwise I like the 2.0a HDR addition.
From their website (http://www.onkyo.ca/Products/model.php?m=TX-NR747&class=Receiver) :"Joining next-generation audio decoding are eight 4K/60 Hz-ready HDMI® 2.0a inputs and two outputs, including dedicated HDCP 2.2-compliant terminals for 4K streaming and UltraHD Blu-ray with Dolby Atmos or DTS:X audio (due later this year). High Dynamic Range (HDR) color and 21:9 cinema-aspect are also supported."
http://www.onkyousa.com/Info/pressreleases.php#359
It says 8 HDMI 2.0a ports. Not sure if they're all HDCP 2.2. What's the use of a HDMI 2.0a port that's not HDCP 2.2?
Yeah that's what it looks like.They look good so far! Has Onkyo divested themselves from Audyssey completely?
I can't find any definitive info if the HDMI inputs are 10.2 or 18 GBit/s. "HDMI 2.0a" only means they support the added signaling for HDR.From their website (http://www.onkyo.ca/Products/model.php?m=TX-NR747&class=Receiver) :
HDCP 2.2 Copy-Protection Compatibility (3 in / 2 out)
The product page clearly says 18 Gbps : "HDMI 2.0a and HDCP 2.2 compatibility supports the latest formats and technologies planned for Hollywood content. HDMI 2.0 offers a significant increase in bandwidth (up to 18Gbps) to support new features such as [email protected]/60 (2160p), which is 4 times the clarity of 1080p/60 video resolution. Version 2.0 is backward compatible with earlier versions of the HDMI Specification."I can't find any definitive info if the HDMI inputs are 10.2 or 18 GBit/s. "HDMI 2.0a" only means they support the added signaling for HDR.
They state "4K/60Hz" capability, but that can be either in 4:2:0 (10.2 GBit/s) or 4:4:4 (18 GBit/s).
I might be splitting hairs here, but generally stating that "HDMI 2.0" can support "up to 18 GBit/s" does not mean that the HDMI ports on the Onkyo actually support that rate. That whole statement is very evasive and open to interpretation.The product page clearly says 18 Gbps : "HDMI 2.0a and HDCP 2.2 compatibility supports the latest formats and technologies planned for Hollywood content. HDMI 2.0 offers a significant increase in bandwidth (up to 18Gbps) to support new features such as [email protected]/60 (2160p), which is 4 times the clarity of 1080p/60 video resolution. Version 2.0 is backward compatible with earlier versions of the HDMI Specification."
Yeah you're right...I might be splitting hairs here, but generally stating that "HDMI 2.0" can support "up to 18 GBit/s" does not mean that the HDMI ports on the Onkyo actually support that rate. That whole statement is very evasive and open to interpretation.
Only 3 of the 8 rear inputs are full 2.0 with 2.2!8 HDMI 2.0a/HDCP 2.2 ports.
They still use AccuEq and dts:x only supports 5.1.2.![]()
