I had some problems with (when i used the video scaler) the 876 that after
1-2 hours it started to put the TV on black for some seconds.
I found that the back part of the case, where the video scaler is, felt very hot.
The 876 was running at 47-48 C.
What i did was that i put 3x 12cm Cooler Master case fans on top and the temp started to drop to 38-39 C !
The 3x 12cm fans fit exact on the opening for hot air outlet on top.
I had the fans running on 3 volt and 4.5 volt so i could (almost) not hear them, 4.5 volt will even go 2 C lower then 3 volts du to the higher fan speed.
And when i cover (yes > COVER > And my problem with the TV going to black is GONE
So i can only conclude that the Onkyo is running to hot (maybe only on specific settings) and that the use of computer case fans on top is a solution to get the temp down, far down......
Now i have 3x 12cm Cooler Master running on 4.5 volt, tomorrow i will get 3x 12cm Scythe Slip Stream 120mm -800 RPM -10.7 dB on 12 volt.
Lets see what these very silent fans will du to the temp on 4.5 or 6 volt....
