Not sure if anyone can help, but after looking at all the threads, this location seems to be the best fit to ask. I have searched the web at many sites to try to correct a cassette deck problem I have. Though I just recently up graded my system to AV, I am very much attached to my old, 30 year old Onkyo 2-channel system and need to have it running like new.
The deck I have is a Onkyo TA-2060. For the last few years the play mode will not work, only turning the tape for a couple of seconds and shutting off. Same with the FF. The REWIND does work seemingly fine.
I`ve spent hours with the deck apart and it does have two visible belts that seem like they do not have anything to do with the drive of the hubs. It has a COUNTER belt that is looped from the counter to the play (right side) hub, there is a second belt that is looped around the REWIND (left side) hub that goes up around a round magnet that has small gap of less than 1mm to a 'HALL IC' sensor (I do not know what this sensor does, I got the location and name of this from a Onkyo service manual that does not explain much at all).
The motor is positioned in the middle of the two hubs. There is a pivoting small, rubber edged wheel, that swings from a smaller brass drive nut to each hub to turn the right side hub for PLAY mode and then swing to the left side hub for REWIND mode. I can not imagine there is a belt behind this pivoting wheel? It looks like the brass drive nut is directly driven by the motor? I just find it strange that this same motor runs the REWIND fine and runs the play and FF for just a few seconds?
Any cassette deck gurus out there with any ideas or suggestions? Appreciate any of your thoughts as I know there are many types of players with different configurations of drives.
This forum seems to have it all? There must be many cassette deck owner`s with similar issues? Maybe in another thread?
Thanks, Xczar
Thanks, Xczar
