I am having trouble setting up the optical audio on my Onkyo HT-S5100. I have the following setup
TV: Samsung Plasma 650
Receiver: Onkyo HT-S5100
Blue Ray: Sony BDP-S301
Satellite: Dish
I have the Blue Ray and Satellite running HDMI to the TV and Optical audio from the TV to the receiver. The receiver is set to DVD with the digital input set to OPT1 (the cable is plugged into OPT1 port). I cannot get any sound. I have cycled through all input settings (OPT1, Opt2, COAX1, etc..) and still no luck.
I attempted to run the cable from the Blue Ray to the receiver and still no sound. I then ran coax from the Blue Ray to the receiver and set the DVD digital input to COAX1, this worked great. The TV does not have a coax port so this is not an option.
I called support and they said I have a bad receiver and to take it back. I took it back and got the receiver replaced (not convinced they actually replaced it, they took it to backroom and said they switched it. They did replace my optical audio cable). With the replacement unit I have the exact same issue.
Is there something I am missing with the setup?
Satellite: Dish
