1 - 8 of 8 Posts
· Registered
Sheesh, man I am sorry!
I am losing it or reading things that aren't there!
I was just reading about power in another thread and assumed you meant the power cord.
Sorry, you just need a simple RCA cable. Again, yes you can pick on of those up anywhere or you can get a better one from one of the sponsor vendors at the top of the page, monoprice, blue jeans, or ebay, etc.
They are standard and if you have a short run a cheaper cable will work fine.
· Registered
They look like (and should be) regular male RCA plug connections. I use RG-6 coax and screw-on RCA plug adapters. Cheaper than anything else, you can get RG-6 in any length you want and it works like a charm. I know the RCA plug it what that Onkyo takes and it looks like what goes into your sub as well.
· Registered
Originally Posted by GlassisWack /forum/post/18251483
went to wally world and got a digital audio coaxial cable.. 15$ and didnt fit.. so back to square one.
A digital audio coaxial cable should fit as well.
They have the same ends. Did you apply enough force when pushing the end into the jack?
1 - 8 of 8 Posts
