1 - 3 of 3 Posts
Hello,
I have an HTIB Onkyo SR-800 ( http://www.onkyousa.com/model.cfm?m=...ss=Systems&p=s ), which comes with the Onkyo HTR-550 receiver.
My question is: while doing the Audissey autocalibration, what settings should I use? (I have read some tutorials here on Avsforum, but I need personalized settings for my particular Onkyo SR-800 HTIB subwoofer/receiver)
I don't have a sound level meter.
1) Subwoofer volume knob set to 1/2, 1/3 or another knob position?
2) Subwoofer level calibration set to: ?
3) Crossover set to: ?
4) Receiver volume (max volume in my Onkyo receiver is 80) : ?
5) Another important settings to configure?
thanks a lot,
James.
Originally Posted by James42 /forum/post/16849158
Hello,
You do not need one.
1. Try 1/2 and see what Audyssey detects as the correct level. You do not want a setting at the extreme (+/-12dB or so).
2. In the Onkyo? Doesn't matter.
3. In the Onkyo? Doesn't matter.
4. In the Onkyo? Doesn't matter.
5. Just the correct number of speakers but I suspect that is not an option with an HTIB.
1 - 3 of 3 Posts
