I hooked up a system for a buddy of mine and have encountered a problem. He has Time Warner digital cable and I have hooked both the coax digital audio out and the analog audio out from the cable box to the video 1 audio in on the receiver. When you first turn the receiver on while the cable box is tuned to one of the lower channels that is still analog the receiver switches to the analog signal and everything sounds fine. Once I switch to a digital channel that is sending a pure digital audio signal and then go back to the analog channel the receiver shows that it has switched back but there is no sound. I have video 1 set to auto/coax. Any suggestions?
