1 - 20 of 770 Posts
I was going to go with the TX-SR674, but I decided that the extra $150 doesn't justify the component, composite, and s-video upconversion. I think that's the only difference.
Anyway, if you own the receiver, please post your opinions here regarding the receiver for audio and/or video purposes.
I have some questions regarding the video connections on this receiver.
Is there any deinterlacing or processing performed on the video signals connected to this receiver?
Is it possible that running my connections through the receiver instead of running them directly to the TV could cause loss of picture quality?
Will the TX-SR604 accept 1080p via component?
I just pick up one this week. I haven't installed it yet though. It'll go into the rack in the theater room of my almost finished new house, in about two weeks.
I don't know yet about the deinterlacing. At a minimum, I'm assuming 480i -> 480p.
As for running your video connections through the AV receiver, I would think that that anytime there is upconversion/transcoding of an analog input, the result could be skewed. At the very least, the unconversion algorithm has to "fill-in" the missing pixels during upconversion.
If it's a pass-through though, I would still think there is the potential for some minimal signal loss.
I bought the 604 almost 2 weeks ago. The only problem I have so far is running component video through it. When I do, I get an horizontal pink looking line that scrolls up the screen from the bottom to the top. When I connect directly from the HD-DVR to the TV, the line is gone, so I am assuming that it is coming from the receiver. (My tv is a brand new samsung s5087W). So I just have connected the DVD and DVR directly to my tv for now. I have not found an answer to this problem yet. I am in the process of getting HDMI cables, so hopefully those will work and I can ditch the component connections.
Other than that, I love the receiver. I would agree with others that it does run hot though. But I do like to play it loud.
According to the onkyo website, this receiver does NOT perform de-interlacing:
Video Features
HDMI Video Upconversion - NO
HDMI Switching Input/Output 2/1 (repeater)
HDMI Bandwith up to 1080p
HDMI Version 1.1
Deinterlacing for HDMI Output (480i to 480p) - NO
Composite and S-Video to Component Video Upconversion - YES
Composite to S-Video Conversion - YES
Also, if you have full size front tower speakers, make sure follow the speaker setup otherwise it assumes they are all bookshelf size and will automatically limit (100Hz) the frequencies it sends to them.
i've been pretty happy with my 604. sounds great, though it does run hot. i just made sure to give it adequate ventilation.
as for video pass-through, most of my higher fidelity sources are hdmi (dvd, hdtv), which work great. my only complaint is that the 604 will NOT process audio via hdmi without an hdmi display connected. it works great when i'm using the HD pj, but during daytime hours we use an old CRT, and we have to manually switch the digital source to the toslink. not a huge issue, but an irritating one. if your HDTV doesn't have hdmi and you're thinking of using this receiver with the new tosh A2, don't think you'll be able to pull TrueHD off the hdmi. you won't, not without an hdmi display connected.
also, as others have pointed out in other areas of the forum, it doesn't have pre-outs.
otherwise, this is a great receiver, and a stellar amount of performance/features for the money.
Discussion Starter · #5 ·
It has a sub pre-out doesnt it?
Discussion Starter · #6 ·
Is there such thing as like an HDMI separator box that if you run an HDMI source to it, it will split it into 2 HDMI cables, 1 with the audio on it and the other with the video on it?
just curious... what would the benefit of this be?
FYI, the onkyo 604/674 does allow you to set whether the audio on hdmi is passed through to the display or not.
Discussion Starter · #9 ·
So the video could be untouched while the receiver processes the audio.
i don't think there would be any advantage here - the video would be just as "touched" by the device separating the video from the audio as it is by the receiver currently (it passes up to 1080p video through - in theory, without degradation).
that's not to mention that the onkyo (possibly others, too?) will not pull off the audio unless an hdmi display is attached. i've not found it explicitly documented (though i have experimentally determined it), so it's possible that my player simply isn't satisfied with the hdmi handshaking without a display attached (and thus isn't sending the audio in the first place without a display on the other end of the receiver).
I've got a Pioneer Pro-730HD with DVI input which I use a cable to convert from HDMI to DVI. I'm thinking of buying the A2 and wanted to use the 604 so I could get TrueHD audio.
Am I going to have a problem like this one?
I have the same question. I have an older CRT HDTV but it does have a HDCP compliant DVI input. I was planning on going with an HDMI -> DVI cable to go from receiver to tv. Will the audio still work fine?
If so, does the 674 have the same problem or does it account for that (since it does transcoding or whatever it's called).
Discussion Starter · #13 ·
Has anyone noticed any signal degradation of component or HDMI sources when running it through the TX-SR604?
I have a Vizio 50" plasma and I did not see any signal loss with component or HDMI. I think that anyone who has a problem with the display should look at your cables first. The Vizio has a faroudja chip that allegedly upconverts video.
What about composite or S-Video?
This receiver looks like a real bargain compared to its competitors. A few observations about some of the questions raised here.
While a split out box to split HDMI into audio and HDMI video would be nice I strongly suspect that this compromises the HDCP "rules". That is you have the audio "in the clear" and can record it via a standard TOSINK. Yes, this is absurd but then HDCP is pretty much absurd.
This may be the issue for the requirement to connect a display in order to get the audio. That is the display agrees that all is well in HDCP land so the audio plays. Does anyone know for sure that any receiver works without a display connected?
The pink bands wondering up the display could be grounding problems. In some cases just plugging the receiver, source and display into the same power strip can might fix it.
If you are simply "switching" component you should see minimal degradation. On an A-B comparison you MIGHT be able to see a difference. This comes from the fact that you have more connectors (4 rather than 2) so there is some theoretical loss. Internally this is a basically a switch which means its unlikely to have as much impact as the additional connectors.
The only conversion it is doing is composite and S-video to component. First of all these signals are low bandwidth crap. So its pretty much crap in crap out. I doubt that this receiver does any processing on these signals. So basically its still 480i coming in via component. There is a high end Pioneer Elite which costs twice as much which does a fine job of deinterlacing and its a big deal.
Both S-Video and composite have two channels. Component has three. So conversion is cheap and easy. Its like going from a dirt road to a superhighway, you won't slow down much. Probably 25 cents worth of components.
How did you come up with 4 connectors?
This is the same experience I have, but my lines are black
HDMI does indeed fix the problem, though my DCT 3412 HD-STB has software issues that don't allow me to use my 604 as a switch... it bitches about HDCP
There is an upgrade to the STB but I haven't installed it yet.
So I send video from the HD-STB to my HL-S4676S using HDMI, but send the audio directly to the receiver. Works like a champ, no lines.
Sorry, I wish i could help you there. This is a great value receiver, and I really enjoy mine...
I would hope that HDCP compliant DVI would also work. My projector does have an hdcp compliant dvi connection - if I had a cable long enough, i could test this for you.
I just got this receiver and a sub this last Wednesday... been really enjoying (re-enjoying?) some of my films with full 5.1 sound. Previous receiver only had 2ch ins, no optical and then there was that missing sub...
I haven't fully calibrated the system with a sound meter, yet. Did run through the automated setup, though.
My first question would be, at what volume level do the others that have this receiver run it at? I was used to a pretty low knob setting on my old receiver. When I first started setting up the Onkyo, I put the volume knob to 20 and thought I was having an input problem as I couldn't hear anything at all... It wasn't until around 35-40 that I started hearing anything out of the receiver and I watch films between 60-80 (loud, but not too loud). This is a pretty small room (10x11 or so), so I figured that the 604 would be "too much" power for this little space.
Normally I would blame the speakers, but they did pretty well, volume wise, on the old receiver (some POS low-end Sony receiver from pre-optical days). It also seems like the reference white noise for manually adjusting the speaker levels is at the proper volume.
Other observations:
It does run rather warm, doesn't it?
Not a problem in my environment, though.
It can pass non-standard HDMI resolutions. My HTPC is set to the native resolution of my HD72 (1280x768).
The sound is fantastic. Of course, I *am* comparing the sound to a POS receiver that was
pretty much only driving two front speakers and the center channel...
Hooking a HTPC 5.1 soundcard up to the discreet inputs on the back of the Onkyo sounds decent enough. I'm not sure if it's a good idea or not to do, though. If I shut down or power up the HTPC while switched to that input, the receiver will shut down from the "clicking" of the soundcard powering up. Definitely the fault of the card and not the receiver, though.
-MD
1 - 20 of 770 Posts
