1 - 9 of 9 Posts
I am considering purchasing this receiver. I need to feed both a HDTV and Video Projector (preferably simultaneously) with the two HDMI monitor outputs.
My question is: Are both outputs "live" at one time? If not, how do you switch between "HDMI Main" and "HDMI Sub"? I've studied the owners manual on-line and I'm not 100% sure about this.
Much appreciated,
Brian
No. Only one at a time.
Much appreciated,
Brian
Discussion Starter · #3 ·
Can you switch between HDMI monitor out 1 and 2 via the remote?
Thx,
Brian
Using the Harmony One: Yes.
Using the Onkyo Remote: No.
Thx,
Brian
Discussion Starter · #5 ·
That's what I was afraid of. I don't want to have to open the door on the front of the receiver every time I switch between my HDTV and Video projector.
Just curious, how can the Harmony One mimic pushing a front button on the receiver?
Thanks for your help,
Brian
Oh my goodness! I was just getting ready to upgrade my SR805 to the SR876 because I need multi-room with dual hdmi. Not only do I need both to output simultaneously, but I also need to at times select different sources for different rooms.
Seriously? Is the 876 that crippled????
There are discrete codes available for both HDMi outputs...
Brian
Discussion Starter · #8 ·
Perhaps a bit more detail? Where can these codes be found, and what remotes can implement them?
Brian
The Logitech Harmony setup has it already as far as I know.
Check the corresponding Onkyo threads for it.
What other remotes do support it too I don't know.
Brian
1 - 9 of 9 Posts
