Which bang for the $$ 2.0 electronics stack? ~$350 budget
  • HK 3490 (convienent and solid stereo receiver)
    Votes: 0 0.0%
  • Behringer SRC2496 + Behringer A500 (fully balanced setup)
    Votes: 0 0.0%
1 - 10 of 10 Posts
Budget for this person is $350 ish.
Source would be one or two devices (5 disc DVD changer, MacBook Pro) so one Optical, one S/PDIF.
Looking for bang for the 2.0 audio buck.
Discussion Starter · #3 ·
Originally Posted by MichaelJHuman /forum/post/19549207
Get an AVR, not a stereo receiver, if you want S/PDIF, IMO.
Stereo receivers have S/PDIF...
Discussion Starter · #6 ·
Some do, some don't.
The one listed does...
ok. I looked at the 3490 and saw no mention of DD or DTS decoding. I would not assume just because it has S/PDIF that it decodes all DVD audio.
I would actually recommend an AVR also, just for the extra features. Mainly room correction. You can get a new Denon, Pioneer or Onkyo AVR in that range with great room EQ.
Discussion Starter · #10 ·
+ That. Craigslist was mentioned along with checking out BB for a closeout.
I picked up a Denon 4308Ci for $410 just a week or so ago.
The two things going for the SRC/A500 is a good S/N ratio and plenty of headroom on the amp compared to most AVR/Stereo receivers. The 70's are an easy speaker to drive.
1 - 10 of 10 Posts
