1 - 3 of 3 Posts
· Registered
I have an Oppo 970-HD with an HP2335 23" monitor for my pc.
The monitor works fine with the pc but it is also intended for
video use and has HDMI, composite, s-video, and component
inputs. The monitor works fine when playing DVDs through the
pc's optical drive using POWER-DVD software and the DVI
connection.
The oppo works fine for audio cd's and sacd disks.
However, when the oppo is used to play dvd's directly into the
monitor ( pc off ) there are strong color tints which vary depending
on the choice of connection. This shows both on the oppo logo with
no disk, and during play. Also, with the HDMI cable, the oppo logo
looks good (no tint) for about 3 seconds and then turns to
multi-colored snow and will not play. Both the oppo and the
monitor have on-screen menus with many options and I have gone
through them extensively with no joy. For the connections that
work, the monitor can display the pixel format and some frequency
that it is sync'ing to - most of the results here do not match any
of the 24 combinations that the monitor docs list as being
recognized - yet they work, except for the color cast and HDMI.
Searching this forum does not seem to find any matching posts.
Ditto for support at oppo and hp.
Does anyone have a clue? Thanks.
· One-Man Content Creator
That sounds like lack of HDCP on the monitor. There is an unsupported firmware hack for the 970 that removes HDCP: http://www.avsforum.com/avs-vb/showthread.php?t=832356
-Bill
1 - 3 of 3 Posts
