Status
Not open for further replies.
1 - 15 of 15 Posts
This little Oppo is the first HDCDP I've ever had and I've been curious to play around with it a bit. When I put in an HDCD the player doesn't seem to do anything that would tell me it's doing anything different with it vs. a plain old CD. It's been my understanding that an HDCD player will somehow display the fact that it has an HDCD but I can't seem to find anything online or in the manual regarding HDCD playback with this unit. Can anyone give me a hand?
jc
the oppo doesnt seem to have a HDCD indicator like most other CDP's that support HDCD, i guess we just have to take their word that it play the HDCD's
Discussion Starter · #3 ·
That's kind of a bummer but since this isn't why I bought the player I'm not going to complain too much. Thanks for the reply.
jc
I'm not clear if it actually decodes hdcd or is just capable of playing hdcd disks (like any other cd player). Anyone know more about this?
Every CD player will play an HDCD-encoded CD. But only some will actually decode it (and provide the full benefit from it). I have never heard of an HDCD-decoding player that does not have an indicator light that tells you it is decoding it. I have a feeling the Oppo does not decode HDCD.
Jim, there's nothing about HDCD decoding mentioned in the description of the Oppo on either the Amazon or the Oppo web site. What makes you think it decodes HDCD?
I believe it lists HDCD as a function, though it doesn't specifically say it "decodes" HDCD. Technically, they can say that they can play "hybrid SACD" also (but of course, this will only bring more confusion).
Discussion Starter · #9 ·
I believe it says it does on the website: http://www.oppodigital.com/
"Functions:
* DVD Video/Audio, Divx/MPEG4, VCD, SVCD, CD, HDCD, WMA, DVDR/RW, CD-R/RW, Kodak Picture"
While the manual doesn't mention it, on the actual player I received it has a cardboard tag with the HDCD logo on it. At this point I'm assuming that it's at least supposed to handle HDCD.
*I've emailed support at Oppo since I'm not the only one with questions on this issue.
jc
My guess would be that the player's analog outputs would have to be used to send the HDCD decoded material. If you have the unit hooked to your preamp via digital connection, you are allowing the preamp to decode the cd. So using a digital connection, unless your preamp or receiver has HDCD decoding, you would only get the regular cd stream.
Short answer....use rca jacks to see if there is a difference. :)
Originally Posted by kanefsky
If you need a little light to tell you whether it's decoding HDCD. then who cares if it's decoding it or not? You need someone to tell you it sounds better? :)
I understand. It would be nice to know if the feature is working. The first time I listened to an HDCD on an equipped player, I had no idea it was HDCD or even what HDCD was. The sound was very good, and I saw the light on the front panel. I was mildly impressed.
Although it's arguable whether you can tell the difference, if the specs say that the feature is there, then it should be there in all its lit up glory ;).
Discussion Starter · #13 ·
I'm including the response from the terrific support staff at Oppo. In my original email to them I told them I would do this unless they objected. They didn't. I haven't seen the indicators referenced fwiw, but I'll double check again tonight.
Jim,
The OPDV971H fully supports HDCD. When a HDCD track or HDCD disc is
played, the on screen display (OSD) will show "HDCD" briefly. During
the entire track, the front panel display will show the "HDCD" icon.
When a standard CD track is played, the OSD will show "CD" briefly and
the front panel display will show the "CD" icon.
HDCD decoding is done by the OPDV971H if analog audio output is used.
When digital audio output is in use, it is the responsibility of the AV
receiver to decode the HDCD digital stream.
Best Regards,
Customer Service
OPPO Digital, Inc.
453 Ravendale Dr, Suite D
Mountain View, CA 94043
[email protected]
Tel: 650-961-1118
Fax: 650-961-1119
Check out the new OPPO DVD home theater system
http://www.oppodigital.com/opdl317.html
OK. I popped in an HDCD cd. The Oppo does display HDCD on the screen for a second and there is a HDCD indicator on the front panel of the dvd player.
  • Like
Reactions: Paul.R.S
1 - 15 of 15 Posts
Status
