Sony A90J panel; Marantz SR7015 AVR; Paradigm Signature speakers; Oppo 203 and Panasonic 820 UHD BR.
Question-
Is it "OK" to run an optical digital wire from my High Def STB into my Dolby Digital receiver (they do not give me a coax digital option)...and then use my curently purchased COAX digital wire>>from the receiver into my DVD ? Woluld this present some sort of inconsistency or ill-match-up ? (The angle into the DVD may be a problem for an optical wire as I understand it).
Second- Can you folks recommend a "really good" but not "outrageously priced" optical digital wire (e.g. my "pain threshhold" for example for video wire is...say...Monster 3 -ish quality/price ).
Thanks for advice !
Thanks for advice !
