Optical sound connection question
3756 Views 35 Replies 11 Participants Last post by  comander sid
Hi
Okay so I have a fairly old surround sound system that I want to use with our LG TV.
The main use for this TV is games consoles, mainly xbox 360 (connected via HDMI).
Surround sound system has digital optical cable input as a connection.
TV has digital audio out.
My question is, can I connect the TV to the s.s system so that the audio coming from the TV comes out of the s.s system, if I am getting sound from the xbox into the TV via HDMI?
i.e.   XBOX 360   ---HDMI--->   TV   ---OPTICAL SOUND CABLE--->   Surround Sound System
1 - 20 of 36 Posts
Maybe. Check your TV's owner's manual and/or give it a try.
Many TVs will only forward stereo PCM from their HDMI inputs to their S/PDIF digital audio outputs. Some will forward 5.1 Dolby Digital. A very few will forward DTS. Most only forward 5.1 audio if the signal source is their internal TV tuner or a network audio source.
If the TV path will not work, you can use "HDMI audio splitter/stripper", the box that takes audio from HDMI and outputs through its optical to your surround system.
Originally Posted by Atozea  /t/1519563/optical-sound-connection-question#post_24401172
Hi
Does your TV have TOSLINK optical output or SPDIF optical output or COAXIAL digital output (not optical)???
Same question applies to the input on the surround system. If you don't know the answer, you need to read the manuals carefully and find out!
If you don't know which of the three types you are dealing with, and the differences, you don't have much chance of sorting it out. They are not compatible with each other.
You can only connect one to the other if the input is the exact same type as the output you want to connect it to.
See less See more
There are only two types of S/PDIF:
1) optical (or Toslink)
2) coax
Originally Posted by Ratman  /t/1519563/optical-sound-connection-question#post_24405799
2) coax
Three, actually.
-Toslink
-SPDIF dual optical-fibre link
-coaxial cable (electrical RF signal)
(see Wikipedia "SPDIF")
In any case, SPDIF does not have the bandwidth of HDMI and does not support as many surround-sound formats.
See less See more
Any example of a consumer TV/AVR/etc. that uses dual-fiber S/PDIF (which I would assume would be either SC or ST connectors)? I've never seen or heard of it for audio.
Originally Posted by Ratman  /t/1519563/optical-sound-connection-question#post_24415894
ST fiber is used for pro audio and therefore no doubt someone has appropriated that for consumer use:
http://www.canford.co.uk/BCD-AES-3-AUDIO-TO-ST-FIBRE-INTERFACE-FAB
Classe is a high end consumer brand and their CDT-1 transport and DTP-1 DAC have ST fiber ports.
The 'professor' specifically stated:
so far, there are no examples of that.
Super!
But generally S/PDIF is Toslink or coax for "average" (J6P) consumer audio. We're not addressing pro audio or those with an open wallet for high end/esoteric stuff.
Yeah, if it were high end, I'm pretty sure he'd post the make and model number. "Fairly old surround sound system" will usually mean run of the mill connections.
Originally Posted by SAM64  /t/1519563/optical-sound-connection-question#post_24417400
A dual optical link would likely involve a peripheral that needed 2 way communication, e.g. record and play.
I am intimately familiar devices such as that, one being the Behringer ADA 8000. The ADA 8000 routes 8 24/48 channels through each fiber.
Here's the interface:
There are a goodly number of audio interfaces and also competitive devices that use this kind of link.
See less See more
Which would be two independent S/PDIF interfaces and can be accomplished with Toslink of coax.
Many of us are familiar with ADAT interfaces such as the one you mentioned, however, this is about S/PDIF interfaces, not ADAT....there is a difference.
In your quest to be the all knowing expert, you seemed to have missed the absence of S/PDIF interfaces on the device you so cleverly posted a picture of.
See less See more
Originally Posted by commsysman  /t/1519563/optical-sound-connection-question#post_24414014
Perhaps referencng this:
The dual fiber being the optical fiber and its supporting tube?
The fiber may actually be two different materials molded so as to help retain the light?
See less See more
Arny...
I know you have knowledge and experience. It is appreciated by many.
Arguing and/or posting pictures and being a google expert doesn't help when the KISS principle is usually applicable.
It may be needed with only one poster, but not every poster.
Let's allow the poster in post #6 to address post #7.
See less See more
2
Originally Posted by arnyk  /t/1519563/optical-sound-connection-question#post_24417791
A dual optical link would likely involve a separate TX/RX pair that is not necessary for PCM or bitstream audio.
Originally Posted by Ratman  /t/1519563/optical-sound-connection-question#post_24418390
Arny...
And that my friend can reasonably expected to never happen, based on extensive past experience.
You shouldn't ask him but rather, whoever created the Wiki which states the same thing.
I do know of a couple of products that used dual link optical, both from Sony. It was however a proprietary implementation that separated the clock from the signal (smart thing to do). One is the Sony CDP-R1/DAS-R1 combo:
And the business end showing the cable and connector:
The other is the Sony CDP R10/DAS R10:
And the close up of that:
These are pretty classic products,especially the R1. Were you guys not around when they were announced?
See less See more
5
You're my hero.... antique/proprietary implementations.
No different than Wiki being "gospel". Was that your Wiki entry?
LOL! I just noticed... what is "electorical"? I guess I wasn't around before the spelling changed.
See less See more
3
Originally Posted by Ratman  /t/1519563/optical-sound-connection-question#post_24421854
It is a rather common mistranslation by non-native English speaking people in Japan. Some call it "Jinglish." Here are other examples:
http://www.amazon.co.uk/Panasonic-HX-DC1-HD-Camcorder-1920x1080/dp/tech-data/B004OR0VSQ
"Image Stabilizer: E.I.S. [Electorical Image Stabilizer]"
http://www.panasonic.com/in/business/security-systems/analog-cameras/fixed-dome-cameras/wv-cf112.html
"High sensitivity with Day/Night (electorical) function: 0.08 lx (Color), 0.07 lx (B/W) at F1.4"
http://fyi.toshiba.com:81/KB/file_uploads/7206/es202S-Service-v01.pdf
"(Electorical detector/SW/Sensor)"
See less See more
1 - 20 of 36 Posts
