Status
Not open for further replies.
1 - 7 of 7 Posts
Hi guys,
I posted this in the DVD section, but thought that I'd give it a try here as well.
My DVD player (RP62) doesn't have a coax out, and my new receiver (D912K) only has two optical inputs in the back, and I have need for three. I'm considering buying a Toslink to coax converter from Audio Authority for $70.
My question is, will I lose any signal quality with the converter? Anyone here have any experience with such a converter?
Thanks for your help.
Originally posted by Ferrarisimo
Hi guys,
You will not loose any signal quality. You will loose your beliefs in urban legends though :)
Seriously, even the weak argument about jitter in digital audio transports will not stand here, so go ahead and get a converter.
Kirill
Want to save some money? Check this . I have one between my DirecTiVo and my pre/pro. Sound is superb.
I bought the Audio Authoritiy unit over 2 years ago and it works perfectly. If I were in the market for a converter today I would definitely try the partsexpress model in Larry's post. I doubt very serioulsy that there will be any audible degradation. Good luck.
Jay
1 - 7 of 7 Posts
Status
