1 - 20 of 20 Posts
Discussion Starter #1
Is there a way to determine optimal bracing structure, wood thickness, how much volume should be present between bracing structures, etc?
I am gonna be kinda close on my boxes in terms of having adequate recommended volume for sealed boxes. I want to use as little space as possible for bracing for that reason.
My boxes are very tall in-walls. Dimensions are 9"x77"x21" approximately.
Trying to stay effective but simple... Not planning on finding a cnc router...
Discussion Starter #2
Would a design like this be sufficient? Looks pretty easy to do but uses a fair amount of volume...
Discussion Starter #4
Originally Posted by Mrkazador  /t/1526766/optimizing-cabinet-bracing#post_24592973
You can use dowels for bracing. Front to back, side to side every 8" or so.
So that will have the necessary rigidity I guess, just wood glue them in?
Banned
Originally Posted by blazar  /t/1526766/optimizing-cabinet-bracing#post_24592926
Is there a way to determine optimal bracing structure, wood thickness, how much volume should be present between bracing structures, etc..
Experience.
IME that's sufficient with 3/4 inch construction. Closer spacing will allow thinner panels. For instance, you'd get the same stiffness using 3/8" panels with the braces spaced at four inches as with 3/4" spaced at eight inches.
Discussion Starter #6
Just simply do a lattice inside the box, right?
The tricky part with dowels is glueing end grain. Gotta fit them into a forstner hole or something. Also making assembly tricky. That's where wider planks of plywood or MDF can be useful because you get more glue are on the end of the board, and in the case of MDF it isn't end grain.
Is this a sub or speaker?
Banned
Yes, but a three dimensional lattice, like this:
However, if the cab depth is shallow enough you may not need anything connecting the sides or the top and bottom.
Discussion Starter #9
It is for subwoofers, and yes the cabinet is pretty shallow.
Is the picture I posted of JL audio's inwall design a bad method?
Banned
It wastes a lot of material with bracing on the panel face that doesn't actually do much, and I don't see any actual panel to panel braces.
Discussion Starter #11
That panel face bracing is strange, not sure what they were trying to do except perhaps make assembly streamlined
Premium Member
Originally Posted by tuxedocivic  /t/1526766/optimizing-cabinet-bracing/0_50#post_24593358
Make the holes deep enough to get sufficient area around the circumference.
Well ya, but that's the tricky part. In 3/4" material that doesn't leave you much, and you have to align the dowel as you assemble the cabinet. It can be done, it's just not as easy as a wide piece of mdf/plywood.
Discussion Starter #14
I will likely mix some dowels in between some more typical bracing like in the picture i showed. I can easily make some holes in those braces for dowels which will make "setting" the dowels easier and more accurate.
Premium Member
Originally Posted by tuxedocivic  /t/1526766/optimizing-cabinet-bracing/0_50#post_24596753
It's easy if you pre-drill one hole to depth, and the opposite panel has a through-hole; then they can be done after the box is assembled.
Hey wait, didn't you do just exactly that with your boxes?
Yes I did do it that way. But then you're left with the dowel end to deal with. It will leave you with complications one way or the other. None insurmountable, but complicated none the less. And you need a forstner bit or a thick panel to drill into.
Discussion Starter #18
I have spade bits so it wont be a problem to prep some hiles for dowels if needed.
If a dowel is fit snugly into the box and just butt-glued in place at the end grain, is it really at such a high risk of the glue joint failing and the dowel coming loose? Seems like a good application for epoxy or a polyurethane glue.
Spade bits are fast, but usually the leading point is pretty long so I'm not sure you'd safely get a 1/2" in 3/4" material. I really don't think an end glue dowel is that strong. With vibration they'll pop off eventually. Epoxy or PL premium could work, but I'm not so sure it would be all that strong. Might be fine though.
1 - 20 of 20 Posts
