Status
Not open for further replies.
1 - 2 of 2 Posts
I know we went through this but wanted to get your input guys.
5.1 SPeaker config
Enhanced ON
Main - Wilson WP 6es goes to 23hz
Center -WATCH Center 55Hz
Surrounds - ProAc 1SC - 40hz to 30Khz (this I question ??)
SUBS 2 ( L/R Config) SVS 20-39CS +/- 3 dB 20 Hz-100 Hz
have X-over setting on MC12B as
Mains at 30hz
Centre as 60hz
Surrounds at 60hz
SUBs at 30hz
LFE is off
Is this configure making sense.? would I be missing a gap as SUBS go to 20 and WP go to 23 ?
thanks for your inputs ...more specs and room details can be seen by clicking my link.
Matt,
It really had to make recommendations like this since so much will depend upon preference and your response in the room.
However, I'd personally raise the rears up a bit higher. That should reduce stress on the Pro-Acs and let them play a little louder cleaner.
If you use Bass Enhance your center needs to be much higher up. Otherwise it could be OK where it is.
For your mains to the sub you want the crossover set where ever is the point where the subs reproduce the bass better then your mains can.
Shawn
1 - 2 of 2 Posts
Status
