1 - 5 of 5 Posts
I have an Optoma HD65 projector that won't power on. No lights, no sound, nothing.
It was working fine when I first turned it on but I was not in the room at the time it shutoff. The unit has about 400 hours on it total and it hasn't been banged around at all. It's been ceiling mounted since day 1.
Is there some way to tell if it's only the lamp that has failed and not the unit itself? Would there at least be some lights on or the fan turning?
I don't want to spend $165 on a new lamp if the problem is something else.
If it were just the lamp it would have some sort of LED indicator. Sounds like there is no power. Did you test the outlet to make sure there wasn't an issue? Also, you might want to try the projector in a different outlet.
Start simple first...
1 - 5 of 5 Posts
