1 - 3 of 3 Posts
· Registered
Hi
I have couple of year old Optoma HD70 projector. I recently installed it on the ceiling.When I started the projected, it worked fine for few minutes and then the image froze and eventually disappeared. All I see now is randon black spots (almost like white noise) and nothing else. No menu options or any other system messages. I do think that it is responding to the menu since it will shut down if I press the power button twice.
Is this a bulb issue or the color wheel issue or the system board issue? I dont want to spend money on the bulb not knowing if that is the issue, since I see the white light on the screen.
Any help would be great. If it is the color wheel, where can I buy the color wheel?
Thanks for the help
· Registered
Probably a circuit fry - however:
If not under warranty, open it up completely and suck out every speck of dust and make sure the color wheel is clean. Reassemble and pray.
Plan B: Sell for parts and get an HD65 for $495 from a BB that still has one in stock and wants to clear it.
1 - 3 of 3 Posts
