Hi,
Today I picked the 3 yrs old vtf-3 and sub looks like in good condition and my system is almost done with the following config:
2 Athena B1
1 Athena C1
2 Athena S.5
HSU VTF-3
Onkyo 501
The origional owner was using the crossover on the sub and it was working great but I search on the forum and found numerous receommendation on switching off the crossover at sub and let the receiever do the work so I set off the crossover on subwoofer and set the speakers and subwoofer at 80hz. I used Radioshack meter and tune everything(speakers+subwoofer) to 75lbs (gain at 12am on subwoofer and 0dbs on receiever to make it 75dbs). Also i am keeping the phase setting at 0 and using rca input on subwoofer.
Now i can see 2 issues with the setup:
I am not getting much bass/output from the subwoofer, What different options should i try? Also Which movie can i try to test the subwoofer.
Also it is mention that when receiver will go off this sub will also be off but i can still see green light on subwoofer even after switching off the receiever for 2 hrs, What can be the possible issue?
--rubs
2 Athena B1
1 Athena C1
2 Athena S.5
HSU VTF-3
Onkyo 501
--rubs
