Status
Not open for further replies.
1 - 2 of 2 Posts
Hi all.
I really need you help on this one. Yes, raster, it's OT.
I work in cable television(hurra), and we have a certan brand of digiboxes that
the end-users use to get a MPEG 2 stream through RF. Now, many of these
custumers have problems with a single channel or several, missing and the
digibox reports 'Problems with the signal'. It is then suggested to the customer
that they try to change their coax cable, running from the wall socket to the
box, and it usually helps. Many customers refuse to do this and get extremely
angry(that's the spirit here), and then we send a tech, who then change the cable
at th customers place, and write them a bill, since it was in their own installation
the problem was.
Now, the question is: How the heck do we avoid the endless fight with each and
every customer regarding this problem, and more important, how can it be,
technically speaking, that one channel or so can be missing? I'm looking for what's
going on in the cable here.
Thanks for your time,
Nicholas
Most likley, there is rf hash comming through the cable,and on this brand of box the rx gain is higher than most. You can test by trying a 10db pad on the input of the box.
Or just give a good cable with the box to start with.
dave
1 - 2 of 2 Posts
Status
