Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
Does anyone have suggestions for a good OTA antenna to use on the balcony of an 8th floor condo. I currently am looking for a better alternative to the Terk 55. I have my satellite dish mounted on a 1 1/4 inch pole that is cemented in a flower pot. The only option in my building is to mount an antenna on the balcony. Any help would be greatly appreciated.
· Registered
If your balcony faces in the general direction of the transmitting towers, consider the Channel Master 3021. Not too big, it's a great performer. If not, try one of the great indoor antennas like the Zenith Silver Sensor. Experiment with location placement. If you're not too far away (say, within 20-30 miles of the towers) you might get good results.
1 - 2 of 2 Posts
Status
