I just put up a channel master 4228 on my roof. How do you ground this? Is there a special screw on 4228 or any metal part of 4228 or long pole will do?
Then where do you run the ground wire to? I already have DISH satellites, and I noticed NO ground wire from dish to multiswitch and no ground wire from multiswitch to anywhere. Just the coaxes from dish and coaxes from multiswitch to my house are visible. Did DISH skip grounding? (b/c Los Angeles ?)
There is a "ground screw" on the multiswitch. Can I just run a ground wire from my antenna to this screw?
Thanks for the help.
