I think I have completed thorough research first, and have a few detailed questions or confirmation needs remaining. Thanks for any help.
1. When combinining separate UHF and VHF antennas, does it matter whether its outside on mast as soon as possible, or 25 ft later, just inside attic.
2. If I were to add FM via separate antenna, would there be too much loss of signal to combine with one of the other antennas then combine again with the remaining one? (better to run separately?)
3. Grounding - Bottom of galvanized steel tower, on cement block and alongside house, is now buried 5 ft because of landscaping change. I guess this is not an adequate ground of the mast and a wire should be run from it to house ground electrode?
4 Grounding - Sat dish, VHF, and separate UHF antennas all have cable coming into attic on side of house opposite where house electric panel is. ALL cables need static discharge/ground block I guess. Is it ok to ground these to a separate nearby ground rod so lang as I then then bond that to house electrode?
5 Grounding - When bonding per 4 above, do I understand correctly that I can join the new ground rod and mast at one end of the house and then run a single combined (and insulated) wire back into the INSIDE of the house till I can attach to house electrode?
