Status
Not open for further replies.
1 - 2 of 2 Posts
Any suggestions for a OTA antenna that needs to be installed in the Attic. I'm located in the SW area of Orange county,Orlando Florida,Thanks Russ
Russ;
I am over in Titusville and just put up the Terk 55 I get 2,35 almost 6, 17-1 and some others in Digital. With some tweaking I feel sure that I will get them all in then drop the "local channels" on DTV. From your house you should get them all. Mine is outdoors but you are much closer. Goto http://comsumer-direct.com they are %59.95 plus $9.87 shipping not $99. Good luck and good viewing.
[This message has been edited by findango (edited 09-29-2001).]
1 - 2 of 2 Posts
Status
