Status
Not open for further replies.
1 - 6 of 6 Posts
I've got an older non-HD Toshiba 50" RPTV (TP50G90) that has component video input. I was originally going to purchase a Toshiba SIR-T150 stb but it appears the device can only output wideband YPrPb, and I need a decoder that can output 480i via component output, since I'd rather not use S-Video.
Den on the RPTV forum said that there is at least one stb with 480i component output, but didn't know which it was. Does anyone know of such a beast?
Thanks in advance.
I want to say the Sony HD100 for sure, maybe others too.
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
In general, there is not a lot of difference between 480i from S-Video & component video outputs. I wouldn't base a buying decision on that criteria, unless you never, ever plan on using the stb in any other mode.
Go to the Samsung site and check out the booklet on the SIR-T150, this unit should meet your needs. I like mine.
The RCA DRD485RG also has component 480i out. I've seen it for around 150 bucks as a standalone unit. I have no experience with it, but I did remember seeing it while browsing one time. Hope this helps.
Eric
1 - 6 of 6 Posts
Status
