Status
Not open for further replies.
1 - 3 of 3 Posts
So here is my problem, just like everyone else. I am in Gainesville, VA about 30 miles from DC. I had a brand new dish installed with all new cable. This runs into a 5*8 powered terk switch. I have a diplexer off the wall cable to accomodate the HD OA and satellite.
My box is a Hughes HTL-HD and I am using a Winegard HD9095P antenna. I have pointed the antenna in my attic at 80 degrees. I am not using a pre-amp or amp.
Problem is NO SIGNAL. VHF channels are snowy, but I am indifferent. I know that we can receive HD out here because my neighbor does. Any help anyone can offer? This has been an expensive and frustrating experience.
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
Be specific with topic titles. See my edit.
Get the antenna on the roof (out of the attic) (sounds like you may need to go well above the roof), possibly with a rotor, maybe also with a pre-amp (put the pre-amp between the Terk switch and the antenna. If that doesn't do it, start looking at the Terk switch and run a dedicated cable from the (now outside) antenna straight to the HDTV receiver.
With that antenna you should have no problems - if you get it out in the open air where it was designed to work.
And don't try saying anything about antennas and your HOA (if applicable) - see my sig.
1 - 3 of 3 Posts
Status
