They could legally challenge something sticking out of your bedroom window, on safety grounds.
Also, many are now using a rule-of-thumb called the "Shrink-Wrap Test": If the building was covered by a layer of plastic shrink-wrap, would your antenna (or any other objects) touch or press through the shrink wrap? If so, they could make you remove it.
If you have a straight shot at the bird from your window, you might get reception through the glass, or a plastic replacement you could put in the open window. It may not work through glass, or even plastic, if the angle is too oblique though, in which case the window would just have to be open when using the dish.
Are they going after everyone with dishes? Maybe it's time for a community dish(s) on each building.
