I am planning an attic antenna installation. The easiest thing for me to do is to run the coax out a soffit vent and then down to the existing cable entrance to the house. I would not have to fish anything through walls or anything else and can simply run it through the vent. However, none of the coax from Monoprice or others are rated for outdoor use. If I am simply running it down the side of the house from the attic (about a total of 10 feet exposed to the elements) do I need outdoor rated RG-6? If so, where is the best place to find some for a reasonable price? The total run would be about 40-50 feet. Thanks.
William
William
