Status
Not open for further replies.
1 - 4 of 4 Posts
We're getting our windows replaced, and the contractor told me I need to move the cables on the outside of the house up about 4". Since my wife hates the look of the exposed cable, I figure this would be a good time to enclose them in some kind of raceway. The house has thick stucco, and in addition I want to be able to paint the raceway to help it blend in. I'd thought of 1/2" PVC with brackets, but that seems it would be as ugly as the exposed cable. I'd like to find something more flat.
Any suggestions?
Premium Member
Originally Posted by Kevin Golding
Any suggestions?
Run them through the walls. Running outside is a kludge.
Discussion Starter · #4 ·
Unfortunately, going through the walls isn't an option, or at least a time-effective one. The two cables are on the back side of the house and split, with some going to the 1st floor and some to the 2nd. I'll check out the Wiremold.
Thank you both for your input.
1 - 4 of 4 Posts
Status
