Status
Not open for further replies.
1 - 20 of 22 Posts
Discussion Starter #1
I'm sure some of you seen this, but if not good. Looks like everyone is getting into the sub game.
http://www.outlawaudio.com/images/su...pective_lg.jpg
http://www.outlawaudio.com/images/sub_bottom_lg.jpg
http://www.outlawaudio.com/images/sub_back_lg.jpg
Model LFM-1 Specifications
Driver Type: Down Firing, 12" Long-throw Woofer
Ports: Dual
Amplifier Power Rating: 325WRMS; 1300W peak
Frequency Response: 25Hz. -180Hz. +/- 2 dB
Crossover Type: Linkwitz-Reilly 4th Order Low Pass Network
Crossover Frequency: 40Hz to 180Hz and Bypass
Phase: 0 to 180 Degrees
SPL: 115dB (subject to placement and room gain)
Dimensions: (HxWxD) 21.75†x 15.0†x 22.0â€
Weight: 58 lbs
Discussion Starter #2
I love this hobby it's always something new coming out for us to talk about. Keeps it fresh. :)
I've read it's supposed to be an HSU STF-2 clone..
STF-3 is the 12" I believe. I'd pay Hsu the extra $20 and get their 7 year warranty over Outlaws 3 years. Anybody figure out how the Outlaw version is 20 lbs. lighter?
There is no variable tune on this model.
The weight is given pre-ship.
Dr. Hsu did help design, but Outlaw had major input too (whereas with STF series, Hsu had 100% of the input).
Two LFM-1s are going now for a special of $999. That is amazing. Quad ports, 650 watts, two 12 inch drivers. A DIYer would be hard-pressed to very significantly top that.
I wouldn't go that far...the DIY'er doesn't have to worry about size restrictions. When you don't care about size(like I didnt' when I built mine) it's not difficult.
Regardless, it still seems like it would be a good deal, I really would be intereted in knowing how similar it is to the VTF-3 though.
sorry I meant a DIYer looking to have a reasonably good finished and similarly sized box/es as a sub system. There is no doubt that any commercial vendor would be very hard pressed to offer as much at that price.
it is tough to say exactly how siimlar to STF-3 it would be. Dr. Hsu had the final decision on everything in the STF/VTF line, whereas with Outlaw he helped design it but did not make all the design decision himself.
Outlaw doesn't have a track record on speakers. They have an *excellent* track record on electronics.
I wouldn't be surprised if they supplied the overall design target and electronics, and Dr. Hsu did much of the enclosure and driver specs.
From what I understand, it is most definitely not a clone of any existing product.
The only real difference I could find is that the Hsu uses a 6th order crossover and the Outlaw a 4th order. What is the function of a cross-over in a sub? Is it used at all if you use LFE input?
Since the STF series and Outlaw arrived on the market at the same time technically it isn't a clone of an "existing" product. A twin maybe?
Difference:
crossover LFM-1 40~180hz higher for satellite
STF-3 30~90hz lower for very hi-end floor
Port position LFM-1 Down port easier to hide the sub
STF-3 Upper Back Can't cover with table cloth
Spike LFM-1 Metal spike with metal disc for hardwood floor
STF-3 Plastic spike recommend rug for hardwood
Enclosure LFM-1 plyglass top
STF-3 Vinyl top
Power swith LFM-1 independent beside auto-on/off (save you 5w)
STF-3 auto-on/off
Line input LFM-1 LFE single
STF-3 stereo dual
Warranty LFM-1 3y electronic, 3y driver
STF-3 2y electronic, 7y driver
price LFM-1 $579+64 shipping
STF-3 $599+50 shipping
promotion: LFM-1 give away $79 sub cable, STF-3 waive shipping cost.
special event: 1st batch of STF-3 is tuned @20hz by mistake, so LFM-1 gets louder and STF-3 gets lower.
If you want to toggle between louder and lower, plain VTF-3 is on sale for $699+free shipping now. (VTF-3 is spec for 350w/rms and +/-1db @20hz, I suspect it uses an ultra driver to achieve it.)
STF-3 auto-on/off
I think the STF has the same switch...just the wording is different.
This one is interesting too, since Hsu recommends 3" for breathing. I wonder how that affects the LFM-1....it is not 3" off the floor.
diamond nice job. thanks.
1 - 20 of 22 Posts
Status
