Status
Not open for further replies.
1 - 4 of 4 Posts
Hi,
I purchased a 65H80 in may and 1:85 material has the same size "black bars" as 2:35 material. The 1:78 material does fill the screen correctly. Is this an Overscan problem? Can I correct this problem in the Service mode?
Also when the "Black bars" are visable there is a very slight inward "bowing" at the corners. I take it that this is what is considered a Geometry Problem?
Would ISF calibration correct these issues or should I attempt to have Toshiba send thier local servicer.
Thanks for any input you have,
Ariel
P.S. Anyone have a contact of a good ISF Tech in Atlanta?
Thanks Again
MY DVD COLLECTION:
i also own a 65h80 and live in the atl, area, i relized the problem within the first couple of days i purchaed it, they sent someone out and they fixed the geometry problem, it doesnt appear to bow anymore, but u can see a little bowtie effect on the edges, but not on 1:85.1 material
1 - 4 of 4 Posts
Status
