2641 - 2660 of 10333 Posts
I had not done much music listening and what I did was from CD, I associated my iTunes library with PLEX and have been listening to music since 4am, (it's 9:20 now) and I am having the loss of the first tiny little bit of the beginning of songs.
My HTPC is connected to the AVR via HDMI from my video card and I know it did not do this with my Harman AVR3700. I remember someone reported this and am wondering if a fix were found?
P.S. The Wife is out, it is at ear bleeding levels & IT FREAKING SOUNDS AMAZING!!!!
I've heard that there is a output boost from most gaming systems. Makes the gaming more "exciting" compared to watching TV. I don't know for sure if there is truth to that, and I know that you say that your old receiver didn't do that, but I just thought that I would throw that out there.
If you swap the connections from your sat box and PS3 (PS3 connected to the receiver where the sat box was, and vice versa) and the PS3 is still louder, then that should tell you that it is how the input devices themselves are configured.
How do you fix that? No idea unfortunately. I have a Dish box, HTPC, and stand alone blu-ray attached to my 1120 and don't have volume issues that great. I do have variance in volume levels for sure (my Dish box is actually a little quieter than the other two, but not a huge difference like you are getting).
I haven't looked, and I am not at home to try, but can you set different "boost" levels per input on the receiver? Again, never looked because it wasn't a big deal for me in my setup. If so, then you could bump up the other sources to match, and then just keep your master volume lower. I had an Onkyo (or was it my old Pioneer Elite) receiver that could do that...
Anthem new Receiver and Processor support Dolby Atmos and DTS:X
Denon has an "offset" for each input to address overly hot inputs. Check the Anthem for input level or something similar if desired. I haven't been bothered by anything enough to look into it.
Not trying to be a jerk, I would have to climb the stairs to check and my knee is killing me lately.
Gotcha!
Going to keep running off questions as I have them...
My output when going on my PS3 source sounds nearly 10 dB louder than when on my DirecTV source. I'm using the same configuration settings for both (though PS3 I'm using a +3 dB bump in sub for movies), and the different was never this substantial on my other receiver to believe that there is a difference in internal settings between the two sources (all processing except "Dolby Surround" is disabled, though both are using DS). Three questions based off that:
1) Anyone else have as big of a jump in sound?
2) Anyone know the reason for this discrepancy?
3) I'd find it unfathomable to set my volume at 0 dB (reference) when watching a Blu-ray, given this. I haven't even crossed 15 dB yet. Because of the apparent difference in volume between sources, is it safe to say that somehow my PS3 is outputting something so loudly that now, say, 10 dB is reference for me instead?
I sholud put this one on film so you can understand the sound differences. It has never been this apparent before.
Which sound mode do ya'll use? I'm currently on Dolby Surround (though I have nothing to upmix at the moment), but I was wondering if None would be the most appropriate for straight/direct passthrough of the codec in ordinary non-upmixing circumstances.
For the input that is louder than the others, you could assign it a different speaker config that has all the trim levels turned down. Open your arc file in manual mode, go to Targets, and scroll over to the level tabs and adjust accordingly. Based on where your trim levels are currently set, you may need to do a combination of raising the trims in your main config and lowering them in the secondary config. If you're already using your four speaker configs then never mind. :)
It's going to be no fun going back there to swap, so I'll just take your word that the PS3 is generally going to play louder on this thing.
Okay, so let's say that my PS3 input is exactly 10dB louder than my DirecTV setup, and let's say that DirecTV at 0.0dB is considered "reference" volume. Given that my current ARC setup has levels as follows (for both configs)...
SW: -4dB (@ -1dB on PS3 by choice)
FL: -4dB
C: -3dB
FR: -4dB
To prevent too much clipping, I suppose what I could do is boost my DTV levels up to...
SW: 0dB
FL: 0dB
C: +1dB
FR: 0dB
... and then move the PS3 levels down to...
SW: -7dB
FL: -10dB
C: -9dB
FR: -10dB
And set my max master volume to -4dB, does that seem like maxing out my volume would be "reference" across the board for both PS3 and DTV? Or is there anything else in the measurements that I must account for when it comes to raising/trimming levels?
Thanks a bunch! Now I gotta figure out exactly how many dB louder my PS3 is than my DTV, and I also gotta determine where reference is determined here.
This isn't specific to Anthem but I ran across this video recently which discusses several options.
Yeah I saw that video a few months ago when they released it. The way he says he hooks up his powered towers is exactly how i have always been doing it. Running LFE and full range on one config. Which i feel was optimal prior to my new sub as my previous didn't go as low.
Well as far as ARC goes, you need to calibrate everything on the LFE output as a single unit, ARC will do whatever is best for your room and the "subwoofer" (be it one, or multiple) in it. If you disconnect the 8060's and then connect them after measuring, you'll "break" the ARC solution since you'll be changing the output of the LFE channel. Take a look at any of the writeups on multiple subs for Anthem, the logic/process is all the same regardless of ARC version. There's a lot of great info in the D2V thread:
http://www.avsforum.com/forum/90-receivers-amps-processors/678260-anthem-d2-d2v-avm50-avm50v-arc1-tweaking-guide.html
Thx I will take a look at this. I figured that would be the case and it would essentially "break" the ARC. I just want t o make sure I'm getting the most out of my sub so if needed I'll just go full range and use the LFE on just the SVS and call it a day. May have to just run a few calibrations to see which is preferable.
@muffinmcfluffin I get that volume increase also with Xbox and PS4. I thought it was due to the decoding of the system sending it in bitstream and uncompressed. All of my sources have roughly the same output except my uverse box which is much lower.
  • Like
Reactions: muffinmcfluffin
I'm not sure I agree that the best way to treat the subs built into the towers as LFE is always the best solution. It might be the best way, but the subs built into the towers utilize passive radiators which are essentially ports. You could end up with some low frequency cancellation between the passive radiators and the true subwoofer.
On the other hand if you connect the subwoofers built into the mains such that they get low frequency information from the left and right channels, then let ARC set the high pass filter you might avoid that cancellation.
Honestly I think you are going to have to try it both ways, take some measurements, listen and see what works best in your space with your speakers.
I do agree that ARC will have to be re-run for either setup.
I switched back to FW 0.44 and now HDMI issues are improved but still a pain, Anthem if you are reading this I pray to the AV gods please do sort this mess out with handshakes it ruins an otherwise great experience.
Didn't we used to have someone from Anthem active in this thread until recently? D'oh... :eek:
Yeah, I think with Nick's departure, it will be unlikely that this thread gets a lot of their attention.
I've been though the official channels already no one was able to help. Frustrating as hell. Nothing to do with this forum.
...Anthem if you are reading this ....
Sorry, I must have misunderstood your statement above in that I thought that you were using your comment, here, in this forum, in hopes that Anthem would be reading it for some reason. :p
Seriously though, I understand your frustration. While I love the sound that I get from my 1120, it was SIGNIFICANTLY more expensive than any other receiver product I've ever owned, and I too have had issues. Buying a premium flagship production should not come with this many issues.
  1. My initial 1120 had a very loud "pop" after it would shut down that came from my rear right speaker. Had to jump through a number of hoops to get it replaced because Anthem support basically didn't believe that it was their problem (which is was and they finally got me swapped out.)
  2. Firmware versions seem to fix some things, but break others.
  3. We still don't have DTS:X when it seems like the rest of the world does.
  4. My 1120 now has a super deep "thud" sound from either one of the front speakers or my subs in the front of my theater during power off. I haven't isolated which it is because they are all behind my false wall and it just isn't something that I think about doing until I am done watching a movie (usually late at night) and it takes 2 people just to take my screen down.
  5. I've had a couple of HDMI video handshake issues recently with my HTPC that go away if I bypass the 1120 for picture.
I never had problems like this with my previous $700 Onkyo. I DID have the HDMI board issue with the Onkyo, but they had me back up in running in just under 1 week with a full repair (including them shipping me an empty box to begin with) vs. the 3.5 weeks that I was without my brand new 1120 because they wanted it shipped back to Canada to "investigate my claimed issue."
So yeah, I don't vent here very often. I do find the sound of the 1120 to be really amazing, but it seems like there are a lot more glitches/bugs that simply should not exist in a top end flagship product. It feels like I am a beta tester sometimes using a pre-production product.
Alright let's let it out:)
I have to say I haven't had the happiest experience with support either, it takes days for them to reply and once the convo gets going often it takes one WEEK for them to reply just to one things I asked in reply, last time it took about 3 weeks for a simple conversation to happen until I actually told them it was ridiculous so they got back to me quicker but apart from putting me on a beta firmware not much else had happened, and looky now I had to revert back to the only stable FW I know.
Pretty disappointing. I also was getting cracking noises on the new FW when the system was idle, so yes for a premium product no matter the sound quality it's s...ts me big time.
Perhaps now you see?
Yes the fractional values are the channels 3/4 means LCR + 4 surrounds; 2/0 means LR and no surrounds. Not sure how it displays overhead channels as I have an MRX700
It displays "Dolby Atmos"
3) I'd find it unfathomable to set my volume at 0 dB (reference) when watching a Blu-ray, given this. I haven't even crossed 15 dB yet. Because of the apparent difference in volume between sources, is it safe to say that somehow my PS3 is outputting something so loudly that now, say, -10 dB is reference for me instead?
I generally watch movies at about -25.
When you say cracking noises do you mean from your speakers or the unit itself. I have heard something that I was having a hard time describing that I guess the best description of it would be cracking or a slight click though it's from the unit itself.
I never argued with you if you noticed.
It's from the speakers when idle, it sound like noise when playing old turntable discs, it's a cracking/popping noise.
It's from the speakers when idle, it sound like noise when playing old turntable discs.
I should have said That was my experience with the phone help, I am not saying you argued.
This issue sounds like a hardware fault to me, I'd keep at them for a solution.
No it's a firmware issue as I mentioned I am on the older FW now again and the issue is gone.
Honestly I am too tired to even type another email to them just to start a month long conversation for nothing.
However this raises the BIG question, if a simple FW update causes havoc what are we going to experience when they release DTS:X (if ever)??
Sorry, I missed a firmware change solved it. I hear you on the email conversations, I can call Canada free so did but every call led to emails and that last one sent me here for solutions. As you found I ended up "figuring it out myself" every time as well.
That is why I was so frustrated.
The last timeframe was by the end of 2016 no? So we'll have DTS-X within 27 days!!!! :p
Yeah want to see that happening and also bug free. Chances are???
