61 - 80 of 11272 Posts
Is ARC version updated on these models?
Same ARC 1M mic kit, modified ARC 2 software to support 11.1, wireless connection and new DSP hardware. As well, two speaker profile memories have been added for a total of four to allow, primarily, ceiling speaker vs Dolby-enabled vs no-height comparative demos.
  • Like
Reactions: sneill
I'd be shocked if this were not the case. I'm sure that in the 1120 you can externally amplify any or all of the 11 main channels.
Now, I think [email protected] confirmed here or elsewhere that on the 720, the AVR amps cannot be assigned to the "height" speakers. So I assume that you need at least four channels of external amplification for the heights on that one. And undoubtedly you can add any number of additional channels of external amplification beyond that.
I would only consider the 1120 if the internal amps can be assigned to the "height" speakers. I already have 7 channels worth of Bryston amplification in a 7 channel setup and was thinking that the 1120 might be an interesting option when I renovate my HT for an 11 channel setup. If this is not possible, then I might as well go with the AVM60.
My current AV processor is an AVM50. I wonder if the AVM60 would be a sonic downgrade from the AVM50 for 7 channel source material.
Does anybody know if the AVM60 will offer video switching for 4K source material. I assume this would require the AVM60 to have HDCP 2.2.
Will ARC be able to calculate the level and phase of dual subwoofers separately similar to sub eq ht?
Just a general question, I haven't used an Anthem receiver yet. Is there a way to keep two profiles in the receiver? I would like to keep one profile with the rear surrounds turned down and the center turned up for times when I have a second row of listeners.
Sent from my SCH-I535 using Tapatalk
I wouldn't imagine there's any "assignment" to do with the 1120. Presumably all preouts are always hot, as that is the general AVR convention. On the 1120 all processed channels have amplification, so just hook up your Bryston to the preouts of choice* and power the other 4 speakers with the internal amp.
*While it seems the convention is LCR + side + rear on separate amp and FH + RH on lower power, I can see a case for doing LCR + FH + side on the separate amp and rear + RH on the AVR as well.
Measured downgrade, probably. One reason the AVM/D have managed to hang around for so long is that Anthem did a spectacular job on the analog hardware. Sonic downgrade, you don't mention if you currently use ARC or Dolby Volume's modeler. If you do, then it's probably a wash on legacy content. If you don't use ARC and DVM, the new one should be better if you do on the new one. We're at a point where, in terms of audible differences, software has a lot more impact than hardware, IMO.
Good to know about the amplifier assignment for the 1120. I suspect the 1120 is the AVM60 with built-in amplifiers. If that's the case, then the 1120 would make sense since it would provide 4 perfectly adequate amplifier channels for the height speakers. I am using ARC with the AVM50 and would plan on doing so with the AVM60 or 1120.
Yes, current gen has two memory banks for speaker profile which consists of level calibration, listener position, bass management, and ARC curve. Next gen will have four profile memories, with each assignable to inputs as before. There are 20 input setup memories so for example, you can insert a new Blu-ray input configuration by cloning the existing one except using a different speaker profile.
  • Like
Reactions: nadyn
That's the default. A pair of heights may be reassigned to zone 2.
Curent-gen switches from and scales to 4K24 / 4K30. Next-gen adds 4K50 / 4K60 switching but there's no scaling of any sort. The scaling chip is still there on the side as a source of OSD graphics which the new HDMI interface can blend with the input. The following are supported - keep in mind this is preliminary info but I see nothing to stop these features:
HDMI 2.0a
HDCP 2.2
On-Screen Display with UHD 4K 50/60
4:4:4 Chroma Subsampling at 4K60 (18.2 Gbps)
High Dynamic Range (HDR) - unverified, test spec pending
21:9 Aspect Ratio
BT.2020 Color
Awesome, thanks for the reply, how quickly can you flip between these profiles, is it assignable on something like a harmony? This may be a redundant question, does the things listed above included everything for a full calibraiton, so I do a full ARC calib for 1 row of seats, store it, then a full ARC profile for 2 rows of seats and store it, then swap when needed?
Just change input. For the two profiles you can run two measurements with different mic positions, for example mic position 1 between the two rows instead of the money seat for the second profile, or you can just clone a single measurement into second profile then change levels manually in the setup menu.
Ways to change input in MRX x10 and MRX x20 / AVM 60:
1. Use the left/right buttons then Select to go to previous/next input - you can set them up in any order, giving each a name up to 8 characters long.
2. Press Input and select from the on-screen list, similar to a TV's except only assigned inputs are displayed so you don't get a list of twenty when you're only using three.
3. Use discrete input codes in aftermarket remotes including Harmony. The new series uses the same remote and commands as the current series except that the Last button doubles as the Home button for MHL sources.
This is a totally awesome feature, thanks for all the info Nick =)
HDMI 2.0a
HDCP 2.2
21:9 Aspect Ratio
BT.2020 Color
Thanks Nick. That's very promising.
HDMI 2.0a
HDCP 2.2
21:9 Aspect Ratio
BT.2020 Color
Currently I'm using a projector that has a vertical stretch feature since I have an anamorphic lens. Are you saying that the next gen receivers/pre-pros will have a similar feature? This would be a plus for those who have lenses but don't want to be limited to buying a projector that has this feature.
The info presented at the HK show is all that's available.
Thanks Nick. I'm wondering because this site shows coming soon for the AVM 60 and MRX720 on page one and the link at the bottom for page two shows coming soon for the MRX520 and MRX320. While I understand it's not an official Anthem site, they are correct about the AMV60 and MRX720 so it makes me wonder if they are also correct about the MRX520 and MRX320.
http://avex.by/catalog/~catsearch/@...OBJ/@sort2/producer_name=asc/@view/producer=1
It's HDMI 2.0 support for 21:9 flat panels which seem to be gone just as quickly as they appeared. For scope projection, motorized zoom is another option.
Thanks, Nick. I am in the "anamorphic lens is best" camp. ;)
Unfortunately, that article seemed biased. It made no mention of the fact that when you zoom, you have to account for image spillover above and below the screen, so you need a super dark velvet in order to not see it (which you still can in bright scenes). Also, I've never had any issues with rainbow and moire issues, and I have an acoustically transparent screen. Get a good anamorphic lens, and the differences in clarity of the image are nonexistent.
But I digress. Now my debate is if I should get the AVM 60 or MRX1120. Does having balanced XLR inputs really make that much of a difference? My RCA cables would only need to be a few feet long since my gear is stacked next to each other...
