Hi, I haven’t searched this thread so sorry, if these were already asked.
I just bought this receiver, upgrading from a HT-S5300 from 2010. The first thing I noticed is that the front and center speakers are much quieter than with my old receiver. I had to turn the volume up a lot to get them about the same as they were previously. When I did that though the subwoofer was deafening. I noticed that the EQ setup set the front and center speaker loudness at -2 and the subwoofer at +7. I tried to manually adjust that, but the level calibration blasts out deafening noise from all speakers without a way to lower the volume, so the level adjustment screen is pointless.
1. How accurate is the AccuEQ thing? I’ve run it multiple times and it always picks the same levels, but the distances change slightly. Also the front crossover changed from 150 to 200 Hz. All my speakers are the same as they came with the S5300, yet it picked three different values: 200 (front), 120 (back height) and 150 (surround). It also picked 90 Hz for center, even though that’s a much larger speaker. What does crossover do anyway?
edit: I found a post I made that listed the speaker frequencies for the HT-S5300 (fronts: 55 Hz - 50 kHz, center: 65 Hz - 50 Khz, backs/surrounds: 80 Hz - 20 kHz, sub: 25 Hz to 150 Hz) and based on that it seems like AccuEQ picked the wrong crossover frequencies. Am I right?
Quote: Originally Posted by Morac Finally I think I might know why the bass sounds too loud. The default "Crossover" setting is 100 Hz (5-1/4 to 6-1/2" speakers). The manual says that this should be set based on the cone size of the smallest speaker in the setup. The surround and...
www.avsforum.com
2. Is there a way to set a volume per input or at least by input type (I.e. stereo vs 5.1 vs Atmos)? Some of my inputs are much louder than others. Edit: I found the “My Input Volume” which does this by input, but not by audio type.
3. The manual says Airplay2 is supported, but it doesn’t really seem to be. Not the way HomePod, Apple TV and Roku are. Those devices can play music separate from my iPhone (I.e. I can play one song on my iPhone and another on the Roku). This receiver can only play what’s playing on the iPhone, though I can add other devices to the group. Is that all this supports?
4. If the input is Dolby Atmos and I set the receiver to Direct mode, will it still “do” Dolby Atmos or does the mode needs to be set to “Dolby Atmos”. I found Direct to sound better on my HT-S5300. Is it okay to use that on this model?
