21 - 40 of 4206 Posts
Banned
why to buy Receiver with HDMI standard outdated !
I waiting for HDMI 2.1
https://www.cnet.com/news/hdmi-2-1-what-you-need-to-know/
When HDMI 2.1 sources and sinks come out, simple: buy an HDMI 2.1 -> HDMI 2.1 + HDMI 2.0a splitter and use your current HDMI 2.0a receiver for audio only. The audio component doesn't need HDMI 2.1 and never will. HDCP 2.2 however, yes, that's important. HDMI 2.0 supports audio-only paths, it doesn't have to have a video signal spliced in.
People have been doing this for years with HDMI 1.4 3D -> 1.3. Yes it's an additional expense but definitely smarter than waiting two years for a receiver which does nothing to the extra ".1" except forward it to your TV or act like a switch.
However, I believe HDMI 2.1 gear will likely be out by next year. In that case, then yes, it might be smarter to wait than spend 2K in 2017, especially if you already have something decent.
IMO all these Atmos receivers are over-priced and under-featured. Seriously, 5.1.2? 5.1.4 is the bare minimum to deliver a proper 3D sound field using point sources.
Premium Member
Discussion Starter · #22 ·
Will the DN1080 pass Dolby Vision? I would hope so since Sony's top of the line TVs support DV.
I just confirmed with Sony that none of the company's AVRs will pass Dolby Vision. HDMI 2.0a certainly has the bandwidth to do it, but the circuitry must be Dolby Vision-aware, which must be specifically enabled.
Wow, even the crazy expensive Sony STR DN5000es won't pass DV? Perhaps a future article can focus on AVRs that do pass DV. It seems like there are very few AVRs that do pass DV which is troubling.
similarly, I am looking to upgrade my 5.1.2 to 5.1.4. There is a pretty significant price jump going to an AVR that can support that set up.
You can probably get a Marantz pre-pro for about 45% off when next year's new model comes out. When the 7703 came out, it pushed the 7702MKII from $2199 to $1199 with no tax and free S&H. Same with the 7010 AVR when the 7011 came out.
Premium Member
AFAIK, there are no major brand 2016 or earlier models that can pass DV. Thus far, only D+M has announced it will add DV capability to the 2016 Denon and Marantz models via a firmware update to be released by early 2018. The new 2017 models of most major brands (except Sony apparently) will likely support DV (at least that is the case for the lower level Denon "S" series just announced a few days ago to be released next month). This is not a major issue; however, as there is currently very little (if any) DV content available not to mention currently only capable of being processed by a couple brands of TVs (LG and Vizio) and once it does become more prevalent, and presuming you purchase a 4k TV that can process it, you can pass the 4k DV video directly to the TV with the HD audio going to the AVR.
Banned
You'll be waiting until 2018 ... and then in 2020 .. the standard will again change to HDMI 3.0. ;)
inaccurate
HDMI 2.0 standard ****ed built without testing ( was no HDR or 4K )
It was built on a bad theories
actual length of cable to 1 1/2 meter
  HDR perhaps to 1000NITS
10 BIT
( HDR +12 BIT NO IN HDMI 2.0 )
Banned
That article says 2018. You will be waiting forever if you are wiling to wait a year b.c something new will come in 2019, 2020, etc.
What content are you going to be watching?
-Can carry resolutions up to 10K, frame rates up to 120fps.
NO
HDMI 2.0 poor standard / working Poor
If you do not know this, we have a problem
Banned
This is from the article you linked. I guess you didn't read it.
A TV bought in 2018 could very well have HDMI 2.1, but even it won't take full advantage of the connection's potential. And a TV bought today will be able to display video to its own full potential using HDMI 2.0. In other words, lack of HDMI 2.1 is no reason to put off buying a new TV.
today with HDMI 2.0 we have only trouble
if you do not know this, we have a problem
Standard built by theory without testing
Nothing works right with HDMI 2.0
Banned
Do not agree
AMD put Warnings HDMI 2.0 cable up to 1 1/2 meters in length
the next version of the HDMI standard version 2.1 an improvement for sound
Adaptive frame rate & better audio support
a new “eARC” features is highlighted. This is an extension of ARC – audio return channel – to enable support for object-based audio formats such as Dolby Atmos and DTS-X.
Why split? from Screen/tv via HDMI 2.1 to receiver
End to SPDIF
eARC in HDMI 2.1 supports the most advanced audio formats such as object-based audio, and enables advanced audio signal control capabilities including device auto-detect.
http://www.flatpanelshd.com/news.php?subaction=showfull&id=1483572084
HDMI 2.1 highlights: immersive viewing and smooth fast-action detail
to really 12BIT + HDR 4000NITS ( hdmi 2.0 built by theories without testing )
hdmi 2.0 1000NITS 4:2:0 leads to incorrect results with 10bit ( It's not just this cable also chip in the tv)
HDMI 2.1 Specification supports the latest color spaces including BT.2020 with 10, 12, and 16 bits per color
Manufacturers do not tell Why we not have REC 2020 ( not hurt sales )
HDMI 2.0 crappy ( for two years no problem reaching 90% in REC 2020 color on led )
so why we have only P3 and no rec 2020 ?
1. Sell More screens ( and not give all in the same year 80%/90%100% OF p3 )
2. HDMI 2.0 crappy Standard ( Do not forget HDMI 2.0 Cable Built FOR HDMI 1.4 the same cable only with 600 hz that Failed )
Dynamic HDR with HDR 10/ Dolby Vision/dynamic metadata 12BIT in hdmi 2.1 ensures every moment of a video is displayed at its ideal values for depth, detail, brightness, contrast, and wider color gamuts—on a scene-by-scene or even a frame-by-frame basis.
( today with content know HDR 4000nits +10/12BIT+p3/2020 ONLY in HDMI 2.1
HDMI 2.0 Built in 2013 So there was no material to test the HDR or P3 or 2020
The trouble began with graphics cards and found that you can barely get 10.2 GHz bandwidth in 4 K
With HDMI 2.0 ( So they invented HDMI 2.0A AND B / Big bull**** )
http://www.flatpanelshd.com/news.php?subaction=showfull&id=1457513362
This AVR just might make me finally replace my HK.
Looking forward to a few initial impressions or reviews.
Having "upgraded" from an HK to the Sony STR-DN860 a few years ago, I'd suggest having a listen before you pull the trigger. I'm not in the "all amps sound the same" camp and was pretty underwhelmed with the difference, especially after all the positive reviews I read about the 860 and it's big brother the 1060. This newer version may sound better, and perhaps you won't hear a difference, but just putting it out there.
Hear ya (get it :) )
The reason for the "upgrade" is for the 2 Atmos channels and the phantom rear surrounds. I had a Sony receiver prior to this HK and I really liked it.
Plus I buy from Crutchfield so I'll have 60 days to try it out. Hopefully it will be as good as the specs.
  • Like
Reactions: rokbyter
I do like the idea of the phantom surround back, but need to wait for an AVR that can support 5.2.4
If you have a 5.1 Setup will phantom back be a waste if your already have rears ? wonder if you can make it phantom surround ?
Sony customer service told me this when I asked about the STR-DN1080: According to their current support documentation available to their customer service/support team, there wasn't anything stating whether the STR-DN1080 would or could receive Dolby Vision support via a firmware update. Doesn't mean it can but also doesn't mean it can't.
They also told me this about their UBP-X800 UHD 4K player: they did have documentation in their system that states this player will be getting a firmware update to add Dolby Vision support.
I'm a little bit of a noob here, but what is phantom surround back? I already have a 7.1 AVR, what is the difference? This one will only do 5.1 + phantom surround back for the other 2 speakers? I'm lost.
The receiver is essentially a 5.1.2 when it comes to number of channels (a total of 7.1). The 2 normal surrounds can be designated as you program/tell the receiver. The other 2 surrounds are intended to be your two Atmos ceiling speakers, but you can also program/tell the receiver wherever you want them to be designated too. It technically doesn't have rear surrounds, but you could designate one of the two pairs of surrounds as rear surrounds. The phantom surround backs are virtual speakers that will reproduce that sound from your side surrounds & ceiling surrounds.
Sony is intending the consumer that buys this receiver will likely have this speaker configuration and is wanting Atmos:
2 L/R Front Speakers
1 Center Speaker
2 L/R Side Surround
2 L/R Ceiling Surround
0 Rear Surround (Phantom output from all other Surround Speakers)
I should've also mentioned that you could use 1 of the 2 pairs of surrounds for physical Rear Surrounds, but then you'd either lose the option of Side Surround or your Ceiling Surrounds (Atmos).
