Settings, Remote & Accessories
Settings, Remote & AccessoriesQuick question how do we get in to the rs232 control menu. My 75 in is doing the exact same thing with he reboots.. also once I get in there ewhat do I have to do or look for. Sorry am new and the tv is not even a month old and now I got this issue.
i have the same setup ( TV/soundbar) and the same behauvior. first image and 2 sec latter sound.Question. As I have said before, I am experiencing really no issues with my tv or audio setup, but I have noticed something and want to see if it is normal as I have not had new av stuff in awhile. I have the 900h and g700 soundbar connected through earc. When I rewind a movie (Either in my xbox or app) and start it again, the movie starts right away, but the audio takes about 1-2 seconds to kick in. Is this delay normal? Seems like when the soundbar sees the signal, it has to show what format it is, then the sound starts.
Lol, they sort of did. In the update log of the new 2.1 update, it said for ps5.Would be false marketing. They did not say 4k/120 only on PS5
That's an interesting point, I wonder if they worded it like that because they knew it didn't function correctly on PCs.Lol, they sort of did. In the update log of the new 2.1 update, it said for ps5.
All my purchased items showed up for watching. I have redeemed a lot of 4K movies in iTunes and they all showed up the Apple TV app in the tv.When I saw that AppleTV app in the apps list I was hoping I could switch my AppleTV viewing from my old AppleTV black brick. No such luck. The app is for a new subscription to AppleTV and none of your old purchases or saved links come across. I'm sure Apple is looking for new subs to AppleTV+. They don't give anything away.
New X900H 55" owner. First 7 days, setup experience and calibrations outstanding. Performed firmware update 2 days ago. Since update, experienced random reboots, inputs randomly dropped, not detected, or no signal indicated. Power cycled attached devices (Sony Blu Rayplayer, Sony PS4), detects as new device? Set device back up, performs normally for a period, switch input and return, sometimes its there, sometimes shows no signal detected. No issues with Arc audio to Pioneer Elite AV receiver so far as others have reported. Unit performed flawlessly prior to update...
Try this:Same issue with my fios cable box. It won't work unless I reboot box. Then it will work for a while but eventually it will stop showing any video or sound. The tv keeps say to turn box on. The remote works to turn on box and change channels. I tried different hdmi cables and different ports. I tried Sony support and all they had me do was factory reset tv. Still have problem. Didn't have a problem for the month I have had tv right until day I got firmware update. Sony told me to change fios box. Makes no sense since it was working fine for a month and nothing changed on box. PS4 and Nvidia shield connected to tv have no problems.
I have the exact same setup as you. The same thing happens with me.This is normal. I believe in the sound bar manual they mentioned that there is a short delay in audio after certain situations. Hope this helps.Question. As I have said before, I am experiencing really no issues with my tv or audio setup, but I have noticed something and want to see if it is normal as I have not had new av stuff in awhile. I have the 900h and g700 soundbar connected through earc. When I rewind a movie (Either in my xbox or app) and start it again, the movie starts right away, but the audio takes about 1-2 seconds to kick in. Is this delay normal? Seems like when the soundbar sees the signal, it has to show what format it is, then the sound starts.
Yes those bugs are not network related. Why buy a Smart TV, if you are not even going to connect it to the internet? Better off just buying a cheaper TV then.I am curious if alot of of the bugs with the software are network related and what i mean is, In my case, if i get this TV, i'd have no intention of leaving it connected to the internet (only would connect it, to upgrade firmware for HDMI 2.1 features) since i have no use for the apps and such. I assume most everyone here keeps their TVs connected to the internet but i wonder if many of the bugs would persist even for a TV that is offline.
I dont see the old version available for download anymore. Even if you placed it on the USB key, I doubt it would allow you to downgrade.Also are we able to revert the firmware of the Sony tv to the previous version before we got the latest. Not sure if it will let us.
No, it will not allow old firmware to be loaded.Also are we able to revert the firmware of the Sony tv to the previous version before we got the latest. Not sure if it will let us.
The RS232 fix is only for the random activating of the receivers/sound bars. It is not for TV freezes/reboots.Thank you will this solve the random freezes and reboots or at least until a new firmware gets released.
Firstly, there are bugs reported related to some of the apps, this much is already known, for instance deleting the tune in app fixes some of the audio issues people have reported. Sure, not all the issues are network related but some are, there is also the wifi bug that had been discussed. I just thought it was worth mentioning, to see if some of the other issues persist even if the TV is offline.Yes those bugs are not network related. Why buy a Smart TV, if you are not even going to connect it to the internet? Better off just buying a cheaper TV then.
Probably the same drop, I just picked one up as well. Late next week I should have my 3080 to test with as well.I was finally able to order a 3080 today, so I will do some testing with [email protected] and post back, will probably get it late next week.
