Dear Forum:
The questions for today are about antennas and their installation, as follows:
I live in downtown Boston, on Beacon Hill ( and high on the hill, with full rooftop access and a basically unobstructed view). The 4 towers in Needham (10-20 miles to the west) broadcast the networks and most of the locals. Antenna installers have recommended a directional antennal with a rotor. With luck, the rotor will require little or no adjustment for my normal channels. (I have tried a cheap inside set-top antenna and it is not strong enough.) All of this sounds fine.
My questions are as:
SIGNAL DISTRIBUTION: If I want to connect 4 TVs (a combination of standard, medium, and high definition sets), there is concern that a 4-way splitter will yield too low of a signal. Should I:
1>Do homeruns from the antenna to each set (this is not easy).
2>Do one homerun to my HD Plasma, and a second run to a splitter for the other three sets.
3>Use some kind of line amplification to offset the effect of the splitters.
WIRES: The interior of the house is currently wired with dual-coax (two coax cables to each set for a and b channels) from Cable Vision. I believe this is less than RG6 (maybe RG5?). There is a central distribution location where the CAVT wire comes in from the outside, and splits to the TVs. It is easy for me to get to this distribution point with my antenna cable. Thus, signal distribution over the existing coax is easiest. But…
1>If the wire won’t carry a sufficient signal, I can do additional new-wire homeruns, if necessary.
2>What wire should I use?
3>Is the answer different for the Plasma, vs. the lower definition sets?
TUNERS: Based upon your prior information, I will wait to get one of the Samsung STBs for the plasma. With regard to the other tvs:
1>For my 27’ Sony Wega high-quality analog set, should I just use the TVs antenna input with no tuner? I am told that it will not handle a HD signal. It there a benefit to an external tuner (assuming I am not using DitectTV)? By using a tuner, could I get DVD quality signal, vs. what I now see over my analog cable, which is poor?
2>For my Panasonic 15†LCD TV (600x800 I think), same question. This set has a built in tuner.
3>For my 12†Sharp (non-Equos) LCD (400x600 I think), same question. This also has a built in tuner.
ANTENNA ROTOR: Do you know if any rotors can be controlled via IR, etc from multiple rooms?
ANTENNAS: Do I rely on an antenna installer and/or dealer to pick an antenna, or do I want more control over the selection?
I think that is it for today.
Thank you, once again.
--Caleb
--Caleb
