P19 tube pin-out question
200 Views 3 Replies 2 Participants Last post by  secstate
OK, Barco, E-home and AmPro 9" projectors take Panasonic P-19 tubes. The pin-out for Barco and E-home are different (2 pins). Which brand is AmPro compatable with (Barco or E-home), without fussing with the neck boards? Thanks,
Chip
Status
Not open for further replies.
1 - 4 of 4 Posts
Barco and Ampro should be the same. Certainly for the 8" that holds true and would expect the 9" to be same.
I'm pretty sure the 8 and 9 inch AmPro's use the same neck boards. So if 8 inch Ampro tubes work in 8 inch Barco projectors and 8 and 9 inch Barco's share the same neck boards then I guess the Barco's work for me.
Chip
Barco 8 and 9" generally use the same neckboards so I agree. I am in the process of putting Ampro Retro P16s into a Barco Data 808s and the pins are for sure the same as the 180DVBs currently in the Barco.
1 - 4 of 4 Posts
Status
