This is an FYI post. I have a Panasonic 50LC13 and everything had been working great with the DVI connection from the Pace DC550P provided by Time Warner. About a week ago I began losing the video and receiving a message that said my tv did not support HDCP and I needed to use component cables. I wanted to let everyone know the scoop from Time Warner:
Pace Micro Technology Americas
DVI/HDCP Update
Pace has currently released software version 1.301.2.12 to SARA sites. Under this release, the DVI/HDCP implementation that was described in Time Warner Corporate Memo titled "DVI Implementation - High Definition Set Top Boxes" has been implemented. However, in certain televisions that are labeled as HDCP compatible, Pace has observed some television specific issues. Currently, Pace believes that our DVI/HDCP implementation is within spec, but these issues could be related to either a particular television's implementation of HDCP or other issues such as Data Corruption when sent from a particular television. In Pace's preliminary analysis, the following Televisions have exhibited the following Symptoms.
Manufacturer
Model Number
Symptom
Sony
34AZXVR910
After some power downs and power ups, the HDCP connection is lost between the Pace 550 and the Television.
Samsung
HLN617W
Never Display Video from DVI port. (Could be HDCP Compatibility issue with the Television.)
Samsung
HLN4365W
While using DVI to watch cable channels, the subscriber switches to a DVD using Component output. After the switch back, the black screen with the incompatibility message is displayed.
Mitsubishi
WS-65413
Television does not pass EDID data.
Panasonic
PT50LC13
Television intermittently drops the video and shows the message on the DVI connection.
The current work around for these particular television models is to merely use the component output. Due to the large number of television types, Pace is still collecting more data from sites to determine more issues if any may arise. However, due to the large number of televisions, Pace does not anticipate testing all televisions for DVI/HDCP compatibility. This is an issue from the manufacturer itself. They are currently working on the problem. Until further notice, component video cables need to be used.
DVI/HDCP Update
Manufacturer
Model Number
Symptom
Sony
34AZXVR910
Samsung
HLN617W
Samsung
HLN4365W
Mitsubishi
WS-65413
Panasonic
PT50LC13
