Hey guys...
What's the current recommendation on paint sprayers? I need something to paint some furniture, but additionally, something that might work to do the theater. I probably won't spray a screen (planning for AT), but would like the option should that change....
I know the Wagner is recommended, but not sure what version, and/or if another type/model is better...
budget is flexible to a degree, but don't want to spend more than Wagner type money unless it would really be worth it...
As an aside, I also already have a decent air compressor setup if an HVLP system should be considered, though I've gathered that spraying latex is best left to the airless setups...
Thanks for any help! (and let me know if i should move this question to another sub-forum...)
-j
-j
