Status
Not open for further replies.
1 - 3 of 3 Posts
dj, it depends on what you mean as ''light'' texture. if it is only very slight it will be o.k. However, in most instances it would be beneficial to sand down the surface as smooth as possible before painting especially if you intend to spray the paint.
It may be easier to put up new sheet rock for the screen and fill the seam if ther is one, the screw holes and sand smoothe and prime and paint it.
then frame it in black velvetine or velvet
1 - 3 of 3 Posts
Status
