In looking at the various posts I seem to think that my projector will do an image squeeze that will accommodate an anamorphic lense for a 2.35:1 image. I don't currently have an HD player so at present my DVD's are all standard, but played through a Sony upconversion player.
My screen has dimensions app. 5 X 12. With the zoom, I get a very nice image but would like to test an anamorphic adapter which I purchased some years ago to expand 16mm "scope" prints. This adapter has a 2X expansion factor.
I notice in some of the Isco literature that the recommended factor for Cinemascope is 1.77. I have done a quick test which suggests that 2.0 may be
too large. *However* I do not know if the projector setting is correct. The most compression I seem to be able to get is with the "V-fit" setting which obviously does not compress the image by 2.
Can somebody give me guidance on how to set this projector for use with an anamorphic lense to get a 2.35:1 image? Note that I am not necessarily saying *this* anamorphic lense, but, if not this, what expansion value should I purchase?
Thank you.
Frank
Note: I get the impression that the anamorphic approach is really only suggested for HD software. I do intend to go there eventually.
Thank you.
Frank
