You would want to move the Panamorph up as much as you can. Moving it up 1', instead of 2', would probably leave you with "minimal" keystone.
If you flip the Panamorph over, you would only move your projector up a little bit, a few inches probably. You won't have keystone per se, but a slight non-linearity, which is mainly visible only on test patterns. At least that's the experience on my (Davis) projector.
Can someone explain what "flipping" the panamorph means? I just installed a JVC G15, had it calibrated and its looks great; I'm just somewhat disturbed at the amount of overscan and wonder how much better the picture would look if I were able to use all that resolution. I watch mostly DVD on the projector.
Also, how does the panamorph affect 1080i HDTV material?
