Status
Not open for further replies.
1 - 11 of 11 Posts
Perhaps a newbie question but searches came up empty. I am trying to determine the optimal connections for my new Panny 300. I plan to connect it to my Marantz SR8000 receiver which should serve as a conduit for my Toshiba DVD player and if possible, my xbox.
I am about to switch to satellite TV from cable and I'm likely to buy a HD receiver.
So, how should I connect these two components into my projector? Which should use S-Video? Which should use the Component In?
Shoul I connect the HD receiver to my Marantz as well?
Here is what I do/would do:
XBox - Component (which will be 3 cables of Red Green Blue)
Sony HDTV box - VGA (like what you use for computer to monitor)
Buy the new Bravo DVD player for $200 and use the DVI input.
Otherwise you will have to switch video through the receiver (does it pass a high enough signal for HD?) or buy a video switcher.
The S-Video is only for lower resolution items like a S-Video capable VCR.
The only other connection is the composite which is one yellow cable. It is the worst type of connection.
Composite and S-Video will not pass 480p or HD...
You probably knew most of this.
Discussion Starter · #5 ·
hmm, I guess I don't see why the xbox should be hooked up directly to the projector as opposed to my main receiver. My supposedly high-end Marantz receiver has what is called "high definition amplifier modules" (HDAM). I'll admit that I don't know what that means but I was hoping that it meant that I could pump progressive DVD, XBOX and possibly a HD receiver through it to my projector. Any thoughts????
I think you need 57MHz to pass a HD signal. You might start a new thread in the receiver section that would address other current owners of the Marantz. I am not sure what "high definition amplifier module" is either.
To me passing the Xbox through the receiver is not a big issue. There is only one 1080i and a small number of 720p's. I would do it in a heartbeat if my receiver was capable...
Hey kingofold the panny does not have a dvi connection to it?So does that mean that you could not hook up any hi def signal to it?Supid question I know.I am just now looking into the thing..
it has a DVI input, I don't think that it is high def copy protected so it won't pass copy protected signals, It seems to me like it should work w/the bravo because that just scales the DVD's to higher formats but I don't know I'm pretty new at this too. Someone should clear this up soon when they get their stuff. I just got an xp30 and am happy but if this bravo works, well that would be annoying (for me)
I'm still a bit confused about this DVI input on the Panny. So since the Panny DVI input doesn't have HDCP, does that mean I can't play a DVD thru DVI cable using my HTPC? Are DVDs HDCP protected?
What's the best way of connecting my Panny to my HTPC? Thanks!
And is it just the DVI that is without the HDCP compatibility? Or the Component inputs too?
1 - 11 of 11 Posts
Status
