Status
Not open for further replies.
1 - 10 of 10 Posts
My DVI connection from my LSS-3200A and my direct Denon 1600 connection via component to my Panasonic 42PWD6 are flawless. However, for the life of my I can't get a picture via composite from my VCR . I know the connections/settings (port, cable, and monitor) are okay since I am able to see a picture when I connect directly to the STB. The VCR is okay since it was working with my old TV. I am connecting the video cable from the VCR "out to tv" to the "video in" on the monitor. What am I doing wrong?
Discussion Starter · #4 ·
Nothing is connected to s-video. When I went to radio shack to get an rca to coax connector (to connect to the VCR), the sales person said I needed an external adapter for the composite connection. Not sure what he was talking about. My thought that I should be able to connect it the same as I did with my old tv.
You will need an RF modulator to connect the RCA (yellow cable) to an F-connector (coax) connection. Does your VCR have a coax output?
Dan
Discussion Starter · #6 ·
My "out to tv" from my VCR is a coax connection.
Since I have a composite cable with BNC and RCA connections, I thought a simple adapter would do.
My VCR is 14 years old. I am going to toss it and get a new one with the right connection so I don't need to use a modulator.
Thank you.
Thank you.
Better idea IMO. :)
Are you sure it is connected to the video in port?
I beleive you need a BNC to RCA adapter (I got one at Radio Shack) to connect the composite video.
After you connect the VCR, you probably will not want to watch it anyway.
My "out to tv" from my VCR is a coax connection. (...) My VCR is 14 years old. I am going to toss it and get a new one with the right connection so I don't need to use a modulator.
It looks to me like this is actually your only option, since it sounds like your VCR has no video-output (typically yellow RCA connector) whatsoever... . RF-modulators I know of - they go the other way: they are used to connect video-output (RCA or BNC) of the source (in this case VCR) to the RF-input (aka radio-frequency, coaxial, F-connector) of the receiver (in this case the TV set).
You need the opposite - to connect RF-output to video-input (since Panny 42PWD6UY has no RF-input). I've never heard of separate RF-modulator (or should it be rather called de-modulator?) doing that. They sure exist ...somewhere, but it very well might be plain cheaper to replace the whole VCR.
1 - 10 of 10 Posts
Status
