1 - 5 of 5 Posts
Hello Crew,
I replaced the Y-SUS board on my Panasonic TC P54S1 with a board from ebay the warranty has expired and I can't locate a replacement board. Can someone tell me if the Y SUS (SC Board) is repairable and How I can go about repairing it?
Originally Posted by str8maxn  /t/1471593/panasonic-54-tc-p54s1-bad-y-sus-board-sc-board-need-help/0_100#post_23285794
You can get a good idea on what is involved here and here .
A member repaired his SC-board using FET replacements here .
Discussion Starter · #3 ·
Originally Posted by tomwil  /t/1471593/panasonic-54-tc-p54s1-bad-y-sus-board-sc-board-need-help#post_23287449
wow.. looks complicated. I having a hard time testing the feds.
thank you for the link
Discussion Starter · #4 ·
So, I open the back of the TV , look at the SUS Y board; look some more, move the connections a little, take my finger and hit each of the FETs. Because I am overwhelmed with the tasks at hand for testing.
Next, I plug in the TV and to my amazement its turns on. Is this normal or do I have a faulty SUS Y Board that just works when it wants to?
Originally Posted by str8maxn  /t/1471593/panasonic-54-tc-p54s1-bad-y-sus-board-sc-board-need-help/0_100#post_23293076
So, I open the back of the TV , look at the SUS Y board; look some more, move the connections a little, take my finger and hit each of the FETs. Next, I plug in the TV and to my amazement its turns on. Is this normal or do I have a faulty SUS Y Board that just works when it wants to?
Glad your TV is working now. Time will tell, but you might have had a loose connection, or a cold solder joint on one of the FETs.
1 - 5 of 5 Posts
