Status
Not open for further replies.
1 - 4 of 4 Posts
· Registered
New 60" Panny home today from CostCo.
Hooked up cable connection and let it autoscan - in fact I've scanned and re-scanned several times now. Problem is that the cable channels aren't getting recognized - majority of them aren't getting set, and the ones that are getting set show up very badly - tons of snow.
Any ideas - been running the same signal w/the same cable to my TV for years w/no problems. This isn't a situation where SD doesn't look so good on a large TV - the snow is so bad the picture is almost completely obscured.
HELP!! Got to convince the wife this wasn't a bad idea.... :)
Dana
· Registered
Discussion Starter · #2 ·
I should note - just to cover the basics, the cable going into the back of the TV is attached to the Antenna A input on the Panny, as spec'd, and the cable feed is coming from the output jack of the VCR (which gets the cable input coming from the wall).
· Registered
Discussion Starter · #4 ·
Weird...switched the cables a few times, originals back in place, and it's working...must be gremlins
1 - 4 of 4 Posts
Status
